[OpenLayers-Users] One Popup situation resolved,
New troubles w/ panmapifoutofview
smithfield
willsmithfield at gmail.com
Thu Feb 5 09:29:23 EST 2009
Thanks for the reply but there is no change when i move it before the popup.
I have tried putting it everywhere. i am thinking that the problem might be
in the centering of the map?
Christopher Schmidt-2 wrote:
> On Wed, Feb 04, 2009 at 10:11:31AM -0800, smithfield wrote:
>> Hello group. Thanks for all of the help so far. I now have the popups
>> autosizing in the correct locations, but i can not get the panmap to work
>> with the popups. I would like the map to refocus so the popup can be
>> seen.
>> You can see that i have the command in my code, but it isn't working.
>> Any
>> thoughts?
>> popup.panMapIfOutOfView(true);
> This is not a function, it is a property. set
> popup.panMapIfOutOfView=true; before adding the popup to the map.
> Regards,
> Christopher Schmidt
> MetaCarta
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://n2.nabble.com/One-Popup-situation-resolved%2C-New-troubles-w--panmapifoutofview-tp2270359p2275102.html
