[OpenLayers-Users] One Popup situation resolved, New troubles w/ panmapifoutofview
Christopher Schmidt crschmidt at metacarta.com
Thu Feb 5 09:33:16 EST 2009
On Thu, Feb 05, 2009 at 06:29:23AM -0800, smithfield wrote:
> Thanks for the reply but there is no change when i move it before the popup.
> I have tried putting it everywhere.  i am thinking that the problem might be
> in the centering of the map?
I gave you two pieces of advice. One was that it's not a function, one
was that it should be beofre it is added to the map. Did you try both?
If you did, can you share a link that you have tried it on, or attaach a
full HTML file that someone can look at?
-- Chris
> Christopher Schmidt-2 wrote:
> > On Wed, Feb 04, 2009 at 10:11:31AM -0800, smithfield wrote:
> >> Hello group.  Thanks for all of the help so far.  I now have the popups
> >> autosizing in the correct locations, but i can not get the panmap to work
> >> with the popups.  I would like the map to refocus so the popup can be
> >> seen.
> >> You can see that i have the command in my code, but it isn't working.
> >> Any
> >> thoughts?
> >> 		popup.panMapIfOutOfView(true);
> > This is not a function, it is a property. set
> > popup.panMapIfOutOfView=true; before adding the popup to the map.
> > Regards,
> > Christopher Schmidt
> > MetaCarta
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
> View this message in context: http://n2.nabble.com/One-Popup-situation-resolved%2C-New-troubles-w--panmapifoutofview-tp2270359p2275102.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
Christopher Schmidt
MetaCarta
