[OpenLayers-Users] Override maxExtent for one layer
Luca Casagrande thedoktor78 at gmail.com
Thu Feb 5 09:56:05 EST 2009
Hi Keenth!
Nope, the map's maxExtent is set to Italy, because if I set it to Europe a
lot of transparent
tiles are generated. I solved the problem setting maxExtent properties for
the layer with a bigger extent.
The problem now is with tilecache as I reported in the ml (sorry for cross
posting)
http://n2.nabble.com/TileCache-and-maxExtent-td2268163.html
Thanks
Luca
Kenneth Skovhede, GEOGRAF A/S wrote:
> Have you experimented with the displayOutsideMaxExtent property:
> http://dev.openlayers.org/releases/OpenLayers-2.7/doc/apidocs/files/OpenLayers/Layer-js.html#OpenLayers.Layer.displayOutsideMaxExtent
> I imagine you set the map's maxExtent to Europe's, and then each layer
> gets the maxExtent that suits it, with displayOutsideMaxExtent set to
> false.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Luca Casagrande skrev:
>> Hello everybody.
>> In my project all the data cover a small part of Italy so the maxExtent
>> is
>> set to this area; now, if I use a WMS layer with a bigger extent then
>> this
>> one (Europe), it get cutted.
>> I tried to set the maxExtent of the project to Europe, but then all
>> layers
>> load a lot of transparent tiles that I'd like to avoid.
>> Is there a way to override the maxExtent just for one layer?
>> Thank you very much for your help.
>> Luca
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://n2.nabble.com/Override-maxExtent-for-one-layer-tp2265408p2275254.html
