[OpenLayers-Users] loadURL returns a pdf
bartvde at osgis.nl bartvde at osgis.nl
Fri Feb 6 09:00:27 EST 2009
I did not find a way to do this with AJAX. So if you find one, I'd be
interested :-) but my search back then indicated this is not possible.
So I ended up doing the following:
1) my script sends the url to the pdf
2) I set the url as the action of a form and submit the form
3) the download dialog starts
I also had to have a static form in my HTML page instead of inserting it
with javascript, since otherwise IE would end up opening a new window.
Best regards,
Bart
> Dear users,
>   Still looking for a way to achieve this.  Does anyone have a hint ?
> Alexandre
> Alexandre Dube wrote:
>> Hi list,
>>   Can I load a script that returns a pdf using loadURL() ?  It currently
>> returns "Unhandled request return OK" but if I copy the URL in a new tab
>> I get my pdf correctly.  Any idea what may be wrong ?
> Alexandre Dubé
> Mapgears
> www.mapgears.com
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
