[OpenLayers-Users] loadURL returns a pdf
Alexandre Dube adube at mapgears.com
Fri Feb 6 09:07:02 EST 2009
Hi Bart,
  Do you mind showing me a snippet of what you did ?
Many thanks,
Alexandre
bartvde at osgis.nl wrote:
> I did not find a way to do this with AJAX. So if you find one, I'd be
> interested :-) but my search back then indicated this is not possible.
> So I ended up doing the following:
> 1) my script sends the url to the pdf
> 2) I set the url as the action of a form and submit the form
> 3) the download dialog starts
> I also had to have a static form in my HTML page instead of inserting it
> with javascript, since otherwise IE would end up opening a new window.
> Best regards,
> Bart
>> Dear users,
>>   Still looking for a way to achieve this.  Does anyone have a hint ?
>> Alexandre
>> Alexandre Dube wrote:
>>> Hi list,
>>>   Can I load a script that returns a pdf using loadURL() ?  It currently
>>> returns "Unhandled request return OK" but if I copy the URL in a new tab
>>> I get my pdf correctly.  Any idea what may be wrong ?
>> Alexandre Dubé
>> Mapgears
>> www.mapgears.com
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
Alexandre Dubé
Mapgears
www.mapgears.com
