[OpenLayers-Users] loadURL returns a pdf
bartvde at osgis.nl
bartvde at osgis.nl
Fri Feb 6 09:20:37 EST 2009
Hi Alexandre,
I've got a PHP script which will return in JSON the url of the pdf,
something like:
{success: true,
'url':'http://test.intranet.rijkswaterstaat.nl/apps/geoservices/ms_tmp/layout_498c466c_441e_1.pdf'}
then my download function will set it to the src of an iframe making use
of a download.php script (which sets the correct http headers for starting
a download dialog in the browser):
download: function(response) {
var res = eval( "(" + response.responseText + ")" );
this.iframe.dom.src = GeoServices.ScriptsUrl +
'/download.php?url='+res.url;
GeoServices.getApplication().hideWaitScreen();
The iframe was created like:
this.iframe = Ext.get(Ext.DomHelper.append(document.body,
Ext.apply({tag:'iframe', style: 'display:none',
src:(Ext.isIE&&Ext.isSecure)?Ext.SSL_SECURE_URL:''},true)));
So actually I am using an iframe and not a form (the form was from the top
of my head).
download.php is something like:
<?php
header("Cache-Control: cache, must-revalidate");
header("Pragma: public");
function getContentType($filename) {
$path_info = pathinfo($filename);
$extension = strtolower($path_info['extension']);
if ($extension == 'pdf') {
return 'application/pdf';
} else if ($extension == 'xml') {
return 'text/xml';
} else {
return 'application/octet-stream';
if (isset($_GET['url'])) {
include_once(dirname(__FILE__)."/../../chameleon/htdocs/common/http/HTTPClient.php");
$oHTTPClient = new HTTPClient("", 30);
header( "Content-type: application/pdf" );
header( "Content-Disposition: attachment; filename=kaart.pdf" );
echo $oHTTPClient->doGET($_GET['url']);
} else {
header( "Content-type: ".getContentType($_POST['filename']));
header( "Content-Disposition: attachment; filename=".$_POST['filename'] );
echo stripslashes($_POST['stream']);
Best regards,
Bart
> Hi Bart,
> Do you mind showing me a snippet of what you did ?
> Many thanks,
> Alexandre
> bartvde at osgis.nl wrote:
>> I did not find a way to do this with AJAX. So if you find one, I'd be
>> interested :-) but my search back then indicated this is not possible.
>> So I ended up doing the following:
>> 1) my script sends the url to the pdf
>> 2) I set the url as the action of a form and submit the form
>> 3) the download dialog starts
>> I also had to have a static form in my HTML page instead of inserting it
>> with javascript, since otherwise IE would end up opening a new window.
>> Best regards,
>> Bart
>>> Dear users,
>>> Still looking for a way to achieve this. Does anyone have a hint ?
>>> Alexandre
>>> Alexandre Dube wrote:
>>>> Hi list,
>>>> Can I load a script that returns a pdf using loadURL() ? It
>>>> currently
>>>> returns "Unhandled request return OK" but if I copy the URL in a new
>>>> tab
>>>> I get my pdf correctly. Any idea what may be wrong ?
>>> Alexandre Dubé
>>> Mapgears
>>> www.mapgears.com
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
> Alexandre Dubé
> Mapgears
> www.mapgears.com
