[OpenLayers-Users] IE 6 chokes on "var featureId = node._featureId; " in getFeatureIdFromEvent(). What's up with that?
Christopher Schmidt crschmidt at metacarta.com
Mon Feb 9 14:44:37 EST 2009
On Mon, Feb 09, 2009 at 11:20:03AM -0800, palewire wrote:
> Here's my problem. I've wired up a basic map. Google layer. Plus a feature
> layer with a polygon loaded in via WKT. I have an editing tool bar so that
> the user can, right away, grab the polygon and start moving it around.
> It works perfectly in Firefox, Safari and Opera. But Internet Explorer is
> throwing a "Failed" error as soon as the user grabs one of the vertices and
> tries to drag it.
> My JavaScript is validating perfectly in JSLint. I've run it through the
> debugging suite in Microsoft Visual Web Developer, where it's catching on
> the following line:
> "var featureId = node._featureId;"
> What could possibly be causing that? Is there some pitfall I'm overlooking?
> Lifelines appreciated, per usual.
Does 'node' exist? If it doesn't, then this would be expected behavior.
Is this code inside of OpenLayers, or inside your own application code?
Regards,
Christopher Schmidt
MetaCarta
