[OpenLayers-Users] IE 6 chokes on "var featureId =
node._featureId; " in getFeatureIdFromEvent(). What's up with that?
Christopher Schmidt
crschmidt at metacarta.com
Mon Feb 9 18:38:29 EST 2009
On Mon, Feb 09, 2009 at 02:00:55PM -0800, palewire wrote:
> Continuing to struggle against this one. If I isolate the map on a blank HTML
> page, the form works perfectly in IE6. So my oh-so-genius deduction is that
> there must be a conflict between the form map and my template. (Big
> surprise, the problem is something I did =])
You're pulling from a django template, right? do you have
http://trac.openlayers.org/ticket/1778 as a problem perhaps? is 'dir='
specified anywhere in your code?
-- Chris
> Here's the rub. There aren't any other OL map in my template. And the
> conflict -- or whatever it is -- doesn't arise until the vector layer is
> selected by one of the OL tools. Would could possibly be conflicing with
> that? Seems to weird to me. Could there be something with an identical "id"
> as the Vector layer OL generates? Gah.
> View this message in context: http://n2.nabble.com/IE-6-chokes-on-%22var-featureId-%3D-node._featureId-%22-in-getFeatureIdFromEvent%28%29.-What%27s-up-with-that--tp2298911p2299669.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Christopher Schmidt
MetaCarta
