[OpenLayers-Users] IE 6 chokes on "var featureId = node._featureId; " in getFeatureIdFromEvent(). What's up with that?
palewire ben.welsh at gmail.com
Mon Feb 9 21:12:03 EST 2009
Chris --
Thanks for your continued help as I cast about wildly.
That does not appear to be the problem. What seems to be happening is that
as soon as I introduce the map object to my site template there is an
IE-only error that occurs when the polygon is selected for editing. Right as
it's clicked. If I remove the base template from the equation, it seems to
be working fine, so I'm guessing the problem is a conflict in there.
Are there any other precautions I can take besides making sure that all of
the javascript variables and functions have distinct names?
Christopher Schmidt-2 wrote:
> You're pulling from a django template, right? do you have
> http://trac.openlayers.org/ticket/1778 as a problem perhaps? is 'dir='
> specified anywhere in your code?
> -- Chris
View this message in context: http://n2.nabble.com/IE-6-chokes-on-%22var-featureId-%3D-node._featureId-%22-in-getFeatureIdFromEvent%28%29.-What%27s-up-with-that--tp2298911p2300596.html
