[OpenLayers-Users] Drawing a circle/callbacks/zoom in scale factors
David Potts
dave.potts at pinan.co.uk
Wed Feb 11 05:46:03 EST 2009
Hi List,
I known this question been asked before, but how do you draw a circle
using a google map background?
My first attempt uses a vector feature with a style object, draws the
circle looks great.
Then I tried a zoom in/zoom out, code draws a circle, looks great, but its
not scaled ie its the same size what ever zoom that you do. So I assume
there must be callback function thas invoked when a map is scaled.
Q. Whats the name of the callback function interface?
Q. When you zoom in on google map, whats the scale factor?
Q. Is using a vector feature and a style object the best way to go?
should I be thinking about using the DRAWFeature instead interface
instead?
Dave.
Any views expressed in this message are those of the individual sender,
except where the sender specifically states them to be the views of the
Pinan Software
