[OpenLayers-Users] LayerSwitcher and DragFeature patched for ticket #1666?
Christopher Schmidt crschmidt at metacarta.com
Wed Feb 11 06:50:03 EST 2009
On Wed, Feb 11, 2009 at 01:17:16AM -0800, dalsinao wrote:
> Hi users and any developer around,
> I downloaded and applied the patch singleroot.4.patch attached to this
> ticket #1666.
> It works fine using SelectFeature control, but then the LayerSwitcher
> control doesn't. When you switch off any of the WFS layers in the switcher
> control the features don't disappear from the map; they remain on the same
> location on the map viewport, even if you zoom or pan.
What browser? I don't get this behavior on
  http://dev.openlayers.org/sandbox/ahocevar/singleroot/openlayers/examples/select-feature-multilayer.html
> - Sooner more than later I'll have to use the DragFeature (or ModifyFeature)
> control; I guess they'll have to be patched as well to work correctly with
> this "one single, mother of all vector layers". Again, any idea of when/if
> it's going to happen?
Whenever you sit down and do the work, or someone else feels
sufficiently motivated to do the same.
> - Finally, I understand that all this is should be ready for 2.8, correct?
> Any idea of around when is it expected to release this version?
Probably not. I'm hoping that the SelectFeature changes make it into
2.8, but I doubt that drag/modify feature stuff will make it in as well
without effort that hasn't yet been offered.
Regards,
Christopher Schmidt
MetaCarta
