[OpenLayers-Users] Drawing a circle/callbacks/zoom in scale factors
David Potts dave.potts at pinan.co.uk
Wed Feb 11 07:59:26 EST 2009
Thanks Chris, thats just what I want.
Good point about the projection issue.
Dave.
> On Wed, Feb 11, 2009 at 10:46:03AM -0000, David Potts wrote:
>> Hi List,
>> I known this question been asked before, but how do you draw a circle
>> using a google map background?
>> My first attempt uses a vector feature with a style object, draws the
>> circle looks great.
> What is your goal? Something that looks like a circle on a mercator map
> is not actually going to be a 'circle' on the ground, so if that's what
> you're concerned about, then this doesn't make sense.
> If this is what you want anyway, then the function you're looking for is:
>   http://dev.openlayers.org/apidocs/files/OpenLayers/Geometry/Polygon-js.html#OpenLayers.Geometry.Polygon.createRegularPolygon
>   http://openlayers.org/dev/examples/regular-polygons.html
> the latter is demonstrating using the REgularPolygon drawing control,
> but that uses the createRegularPolygon method internally.
> Regards,
> Christopher Schmidt
> MetaCarta
Any views expressed in this message are those of the individual sender,
except where the sender specifically states them to be the views of the
Pinan Software
