[OpenLayers-Users] setCenter zooming problem.
Christopher Schmidt
crschmidt at metacarta.com
Wed Feb 11 10:57:58 EST 2009
On Wed, Feb 11, 2009 at 04:54:46PM +0100, bzrudi wrote:
> Hi all!
> I have a strange problem and one may know a simple solution. I use
> setCenter() to center and zoom the map to a given location.
> This works as expected without any problem. The problem is I can't zoom
> in before zooming out one level first.
> So in detail, open the map:
> - use doubleclick, mousewheel or use zoompanel to zoom in -> nothing
> - use doubleclick, mousewheel or use zoompanel to zoom out -> works!
> now you can zoom in without any problem.
> I don't have the problem when not using setCenter(). E.g. zooming in
> from max entent works.
> Any idea?
"Share your code."
My guess is that you're passing a string as the zoomlevel: "16" or some
such. run parseInt(zoomLevel) before passing it to setCenter, and see if
that helps.
However, with no code or working example, it's impossible to know if
this is right.
Regards,
Christopher Schmidt
MetaCarta
