[OpenLayers-Users] Local Geoserve WMS not working
Hugo hfpmartins at gmail.com
Mon Feb 16 08:28:44 EST 2009
Hi Ivan,
Firebug says:
Use of getBoxObjectFor() is deprecated. Try to use
element.getBoundingClientRect() if possible.
undefined
Permission denied to get property Location.toString
ccm_cfg.u = (ccm_cfg.u?ccm_cfg.u:''); cc...layer"
/>';document.write(ccm_fl_embed);
ccm_fl.js (line 1)
[Exception... "Component is not available" nsresult: "0x80040111
(NS_ERROR_NOT_AVAILABLE)" location: "JS frame ::
file:///C:/Program%20Files/Mozilla%20Firefox/components/nsSessionStore.js ::
sss_saveState :: line 1909" data: no]
this._writeFile(this._sessionFile, oState.toSource());
Thanks,
Hugo
On Mon, Feb 16, 2009 at 1:07 PM, Ivan Grcic <igrcic at gmail.com> wrote:
> hi,
> what does FireBug say?
> On Mon, Feb 16, 2009 at 1:58 PM, Hugo <hfpmartins at gmail.com> wrote:
> > Hello all,
> > I've beenmaking some experiences with openlayers and mapfish. I have
> postgis
> > database and geoserver up and running. My problem is with wms created in
> my
> > geoserver. I can load this wms in any thick client (qgis, gvsig) and if i
> > choose the mappreview of the geoserver admin page it is also running ok
> (in
> > the openlayers).
> > If i now try to make my own script it doesn´t shows anything. Any hint on
> > what may be happening??
> > This is my very simple code. It is calling openlayers from mapfish (which
> i
> > tried first with google layers and works fine):
> > <!DOCTYPE html>
> > <html xmlns="http://www.w3.org/1999/xhtml">
> >   <head>
> >     <title>OpenLayers</title>
> >     <script type="text/javascript"
> > src="../client/mfbase/openlayers/lib/Firebug/firebug.js"></script>
> >     <script
> > src="
> http://maps.google.com/maps?file=api&amp;v=2&amp;key=ABQIAAAAqjXqK2AnPc3L2h71jEi4pxS89dNBXjbs3KhxedIObIPgZlGU8RSY0Afhq8cq5fuNgI-GZP2m_MM0Pw
> > type="text/javascript"></script>
> > src="../../client/mfbase/openlayers/lib/OpenLayers.js"></script>
> >     <style>
> >         #panel {
> >             right: 0px;
> >             height: 30px;
> >             width: 200px;
> >         #panel div {
> >             float: left;
> >             margin: 5px;
> >     </style>
> >     <script type="text/javascript">
> >     function init(){
> >         var bounds = new OpenLayers.Bounds (-133259.566796875,
> > -329230.621875, 176201.293359375, 304911.746875);
> >         var options = {
> >             maxExtent: bounds,
> >             maxResolution: 2477.1186279296876,
> >             projection: "EPSG:27492",
> >             units: 'm'
> >         map = new OpenLayers.Map('center');
> >         var caop =  new OpenLayers.Layer.WMS (
> >             "CAOP",
> >             "http://localhost:8080/geoserver/wms?",
> >                 layers: 'pg:caop',
> >                 srs: 'EPSG:27492',
> >                 styles: '',
> >                 format: 'image/png'
> >             {isBaseLayer: true}
> >         map.addLayers([caop]);
> >         map.addControl(new OpenLayers.Control.LayerSwitcher());
> >         map.zoomToMaxExtent();
> >     </script>
> >     </head>
> >   <body onload="init()">
> >     <div id="center" style="width: 700px; height: 550px"></div>
> >   </body>
> > </html>
> > Thanks in advance,
> > Hugo
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
> Ivan Grcic
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090216/41140d86/attachment.html
