[OpenLayers-Users] GML and KML styleMap
Arnd Wippermann arnd.wippermann at web.de
Tue Feb 17 12:41:00 EST 2009
Hi Mauro,
    <ExtendedData><SchemaData schemaUrl="#CALOPICOS">
        <SimpleData name="COD_PRO">16</SimpleData>
        <SimpleData name="NOME">COSTA VOLPINO</SimpleData>
        <SimpleData name="NOME_PRO">BERGAMO</SimpleData>
        <SimpleData name="SIGLA_PRO">BG</SimpleData>
        <SimpleData name="COD_ISTAT">16086</SimpleData>
    </SchemaData></ExtendedData>
if these your attributes, then (my guess) the Format.KML parser will not
found anything. It has to be something like <name>Something</name>.
Arnd Wippermann
  _____
Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
Auftrag von Mauro Bianchi
Gesendet: Dienstag, 17. Februar 2009 14:38
An: Christopher Schmidt
Cc: users at openlayers.org; Andreas Hocevar
Betreff: Re: [OpenLayers-Users] GML and KML styleMap
Yes,
I am using v. 2.7 but it's  like the extractStyles attribute  behaves
correctly.
I've come to the real problem in my code: it seems like feature attributes
are not loaded from the KML file (and extractAttributes is set to true).
(I'm debugging with firebug)
This causes visualization problem as I set a "loadend" event which modifies
the styleMap adding a rule based on one of the attributes. This works
perfectly with the GML format.
here is an excerpt of my KML file (with only 1 feature in this case):
<?xml version="1.0" encoding="utf-8" ?>
<kml xmlns="http://www.opengis.net/kml/2.2">
<Document><Folder><name>
CALOPICOS</name>
<Schema name="CALOPICOS" id="CALOPICOS">
    <SimpleField name="Name" type="string"></SimpleField>
    <SimpleField name="Description" type="string"></SimpleField>
    <SimpleField name="COD_PRO" type="int"></SimpleField>
    <SimpleField name="NOME" type="string"></SimpleField>
    <SimpleField name="NOME_PRO" type="string"></SimpleField>
    <SimpleField name="SIGLA_PRO" type="string"></SimpleField>
    <SimpleField name="COD_ISTAT" type="float"></SimpleField>
</Schema>
  <Placemark>
<Polygon><outerBoundaryIs><LinearRing><coordinates>10.085200473748921,45.822
892231012993,0 10.084585250268859,45.824369844126821,0
10.082453051210173,45.825119119054406,0
10.081007598805416,45.82684743097554,0
10.079839599744659,45.828613605040289,0
10.07717727161147,45.830258855140812,0
10.075010482295186,45.832070393590513,0
10.074058365470743,45.834532025789372,0
10.073265850979176,45.837262169208579,0
10.06965146883106,45.839991757279705,0
10.069422672793097,45.842248559262387,0
10.064130839354922,45.846186242510463,0
10.063978762676339,45.846484679629334,0
10.06434346681317,45.847880880744242,0
10.065628096568989,45.849984053949292,0
10.06583877006006,45.852668775022906,0
10.059618008333993,45.853626698390897,0
10.060379779795703,45.8545691964189,0
10.061666817265563,45.856798398052135,0
10.062159359739915,45.86042556732729,0
10.062166458357162,45.861136549440864,0
10.062491195614504,45.862798642438662,0
10.065108076125764,45.864151370298352,0
10.068276042583895,45.865093859662544,0
10.072075944094292,45.865310285186304,0
10.076297156735873,45.86666119250448,0
10.079277324783051,45.868118179615614,0
10.081854931270923,45.869902922584458,0
10.083140114771034,45.871807873298508,0
10.083937880830906,45.874153962689711,0
10.090736923776577,45.868904916714143,0
10.098095854836334,45.859113773118835,0
10.100973987278632,45.857677479099273,0
10.102589304925999,45.857121865281528,0
10.104952026382794,45.857639077088834,0
10.10549408372342,45.855091158649536,0
10.105693309684447,45.854094662090652,0
10.1137341462167,45.847482107958633,0 10.114255005756153,45.84534837924182,0
10.116027434531851,45.844462518344471,0
10.122735862283923,45.836476225598282,0
10.121797095471102,45.835576381034869,0
10.120717567718057,45.834317883315961,0
10.120381475009312,45.833691133795753,0
10.119058597198419,45.83249351040147,0
10.11877669773189,45.831276682048355,0
10.118713269859052,45.831002783035999,0
10.119842908081528,45.829790128259653,0
10.120160355091627,45.828927453139038,0
10.119746843183558,45.828530977131464,0
10.119565205620738,45.827097151264411,0
10.117436113711921,45.826937981496528,0
10.114963648834435,45.825459025574261,0
10.115432920583952,45.823735317328207,0
10.114350889127907,45.822251764759208,0
10.112532429508482,45.820712370359843,0
10.111123144812886,45.819110463619964,0
10.109297908149857,45.817058044204309,0
10.108380256032628,45.815572837402364,0
10.107786712642209,45.813796458819702,0
10.105413813519233,45.813810441626721,0
10.103850765681402,45.812956988036674,0
10.101945727268799,45.811076233310892,0
10.101763303405559,45.809412865143194,0
10.098657051624869,45.808088648873721,0
10.097241706756741,45.807485228316132,0
10.093045867937683,45.805500291707737,0
10.090559449954725,45.804542976919514,0
10.088601629641808,45.807842401601263,0
10.085108910653183,45.816286768196576,0
10.085674454851302,45.822370351516362,0
10.085264836458663,45.822738770296141,0
10.085200473748921,45.822892231012993,0</coordinates></LinearRing></outerBou
ndaryIs></Polygon>
      <Style><LineStyle><color>ff0000ff</color></LineStyle>
<PolyStyle><fill>1</fill></PolyStyle></Style>
  </Placemark>
</Folder></Document></kml>
2009/2/17 Christopher Schmidt <crschmidt at metacarta.com>
On Tue, Feb 17, 2009 at 11:53:12AM +0100, Andreas Hocevar wrote:
> On Tue, Feb 17, 2009 at 10:44 AM, goliah <bianchimro at gmail.com> wrote:
> > I'm trying to load a layer from a local file, using a GML or KML format
> > based on file extension, and applying the same styleMap in both cases.
> > The following code only works for GML but not for KML format.
> > The var filename is the file to load and the var layertype is the
extension
> > of the file.
> > Any hint?
> Without knowing your KML data, my guess would be that the KML has
> inline styles, which would override your styleMap.
Assuming you're using 2.7 though, this shouldn't be an issue with
extractStyles false:
 http://trac.openlayers.org/ticket/1576
So if this is the case, then we should probably look into it and fix it.
Goliah, are you using 2.7? Does this seem like it is possibly the case?
Regards,
Christopher Schmidt
MetaCarta
Mauro Bianchi
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090217/7a7e11ea/attachment.html
