[OpenLayers-Users] Problems with OL and jQuery UI in IE6/7
Roald de Wit roald.dewit at lisasoft.com
Thu Feb 19 19:17:41 EST 2009
Hi Fredrik,
Does your problem still occur when you do a 'document.namespaces' [1] before executing any other JavaScript?
Cheers, Roald
[1] http://www.mail-archive.com/users@openlayers.org/msg01838.html
Lindmark Fredrik wrote:
Thank you for your answer but it unfortunatly doesent solve my problem. I removed the onReady event for the init and added a button to init the map and jQuery UI-dialog and the problem is still there trying to move the dialog.
http://www.lindmark.org/temp/test/dialogtest.html
-----Ursprungligt meddelande-----
Från: Christopher Schmidt [mailto:crschmidt at metacarta.com]
Skickat: den 19 februari 2009 13:12
Till: Lindmark Fredrik
Kopia: users at openlayers.org<mailto:users at openlayers.org>
Ämne: Re: [OpenLayers-Users] Problems with OL and jQuery UI in IE6/7
On Thu, Feb 19, 2009 at 01:08:04PM +0100, Lindmark Fredrik wrote:
I am using OL together with jQuery UI 1.6rc6 and have come across som
issues running it in IE6/7. When I try to move the dialog i get the
error "Error: Failed", this occurs only when i have a vector layer in
OpenLayers and I havent been able to reproduce this in any other way.
Here is an example:
You can't use jquery's $(document).onReady with code that uses vector layers in IE. You have to use body="onload" or something similar, because the document isn't ready to receive namespaces when onready triggers.
Any ideas,  works perfect in firefox...
/Fredrik
Users mailing list
Users at openlayers.org<mailto:Users at openlayers.org>
http://openlayers.org/mailman/listinfo/users
Christopher Schmidt
MetaCarta
Users mailing list
The contents of this email are confidential and may be subject to legal or professional privilege and copyright. No representation is made that this email is free of viruses or other defects. If you have received this communication in error, you may not copy or distribute any part of it or otherwise disclose its contents to anyone. Please advise the sender of your incorrect receipt of this correspondence.
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090220/d0d60f24/attachment.html
