[OpenLayers-Users] Problems with OL and jQuery UI in IE6/7
Zac Spitzer zac.spitzer at gmail.com
Thu Feb 19 20:24:41 EST 2009
try putting jquery before OL in the header, OL does try and put in a $
function itself
and it can be problematic, especially with eveyones favourite browser (ie).
I have that code commented out in my own tree
z
On Fri, Feb 20, 2009 at 11:17 AM, Roald de Wit <roald.dewit at lisasoft.com> wrote:
> Hi Fredrik,
> Does your problem still occur when you do a 'document.namespaces' [1] before
> executing any other JavaScript?
> Cheers, Roald
> [1] http://www.mail-archive.com/users@openlayers.org/msg01838.html
> Lindmark Fredrik wrote:
> Thank you for your answer but it unfortunatly doesent solve my problem. I
> removed the onReady event for the init and added a button to init the map
> and jQuery UI-dialog and the problem is still there trying to move the
> dialog.
> http://www.lindmark.org/temp/test/dialogtest.html
> -----Ursprungligt meddelande-----
> Från: Christopher Schmidt [mailto:crschmidt at metacarta.com]
> Skickat: den 19 februari 2009 13:12
> Till: Lindmark Fredrik
> Kopia: users at openlayers.org
> Ämne: Re: [OpenLayers-Users] Problems with OL and jQuery UI in IE6/7
> On Thu, Feb 19, 2009 at 01:08:04PM +0100, Lindmark Fredrik wrote:
> I am using OL together with jQuery UI 1.6rc6 and have come across som
> issues running it in IE6/7. When I try to move the dialog i get the
> error "Error: Failed", this occurs only when i have a vector layer in
> OpenLayers and I havent been able to reproduce this in any other way.
> Here is an example:
> You can't use jquery's $(document).onReady with code that uses vector layers
> in IE. You have to use body="onload" or something similar, because the
> document isn't ready to receive namespaces when onready triggers.
> Any ideas,  works perfect in firefox...
> /Fredrik
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
> Christopher Schmidt
> MetaCarta
> Users mailing list
> ________________________________
> The contents of this email are confidential and may be subject to legal or
> professional privilege and copyright. No representation is made that this
> email is free of viruses or other defects. If you have received this
> communication in error, you may not copy or distribute any part of it or
> otherwise disclose its contents to anyone. Please advise the sender of your
> incorrect receipt of this correspondence.
> Users mailing list
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
