[OpenLayers-Users] Problems with OL and jQuery UI in IE6/7
Lindmark Fredrik Fredrik.Lindmark at lm.se
Fri Feb 20 03:08:02 EST 2009
Adding document.namespaces doesnt make any difference and neither did switching included files.
When debugging jQuerys selector classes where the problem origins it seems to be a problem for jQuery to read the <group>-tag generated for the vector-layer. All methods and attributes gives a Failed message. You gotta love IE..
/fredrik
-----Ursprungligt meddelande-----
Från: Zac Spitzer [mailto:zac.spitzer at gmail.com]
Skickat: den 20 februari 2009 02:25
Till: Roald de Wit
Kopia: Lindmark Fredrik; users at openlayers.org
Ämne: Re: [OpenLayers-Users] Problems with OL and jQuery UI in IE6/7
try putting jquery before OL in the header, OL does try and put in a $ function itself and it can be problematic, especially with eveyones favourite browser (ie).
I have that code commented out in my own tree
z
On Fri, Feb 20, 2009 at 11:17 AM, Roald de Wit <roald.dewit at lisasoft.com> wrote:
> Hi Fredrik,
> Does your problem still occur when you do a 'document.namespaces' [1]
> before executing any other JavaScript?
> Cheers, Roald
> [1] http://www.mail-archive.com/users@openlayers.org/msg01838.html
> Lindmark Fredrik wrote:
> Thank you for your answer but it unfortunatly doesent solve my
> problem. I removed the onReady event for the init and added a button
> to init the map and jQuery UI-dialog and the problem is still there
> trying to move the dialog.
> http://www.lindmark.org/temp/test/dialogtest.html
> Från: Christopher Schmidt [mailto:crschmidt at metacarta.com]
> Skickat: den 19 februari 2009 13:12
> Till: Lindmark Fredrik
> Kopia: users at openlayers.org
> On Thu, Feb 19, 2009 at 01:08:04PM +0100, Lindmark Fredrik wrote:
> I am using OL together with jQuery UI 1.6rc6 and have come across som
> issues running it in IE6/7. When I try to move the dialog i get the
> error "Error: Failed", this occurs only when i have a vector layer in
> OpenLayers and I havent been able to reproduce this in any other way.
> Here is an example:
> You can't use jquery's $(document).onReady with code that uses vector
> layers in IE. You have to use body="onload" or something similar,
> because the document isn't ready to receive namespaces when onready triggers.
> Any ideas,  works perfect in firefox...
> /Fredrik
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
> Christopher Schmidt
> MetaCarta
> Users mailing list
> ________________________________
> The contents of this email are confidential and may be subject to
> legal or professional privilege and copyright. No representation is
> made that this email is free of viruses or other defects. If you have
> received this communication in error, you may not copy or distribute
> any part of it or otherwise disclose its contents to anyone. Please
> advise the sender of your incorrect receipt of this correspondence.
> Users mailing list
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
