[OpenLayers-Users] Struggling with projections.
Neil Fincham neil at asdf.co.nz
Thu Feb 19 20:57:05 EST 2009
Hi All,
I feel like I have been hitting my head against a brick wall.  There is
probably a very simple answer to this but I just cannot seem to see it.
I am using OpenLayers (Latest and greatest) and mapserver connected to
ArcSDE useing a very simple php wrapper scripted that I will be doing some
pre processing of the data returned.  Using QGIS I can contact the wrapper
as WFS and produce maps quite easily, all good so far.
Pointing OpenLayers at the same wrapper I get nothing but transparent tiles.
I cannot work out what is different, I suspect it has something to do with
the way I project the data but I am now at a total loss
This is the OpenLayers page;-
<html xmlns="http://www.w3.org/1999/xhtml">
  <head>
    <title>MapServer Layer</title>
    <link rel="stylesheet" href="../theme/default/style.css" type="text/css"
    <link rel="stylesheet" href="style.css" type="text/css" />
    <script src="OpenLayers/OpenLayers.js"></script>
    <script type="text/javascript">
	var extent = new OpenLayers.Bounds(2074357.411583, 5394835.845268,
2968416.907590, 6735935.204660);
	var map, layer;
	function init(){
		var options = {projection: new
OpenLayers.Projection("EPSG:2193"), units: 'm'}
		map = new OpenLayers.Map( 'map', options);
		layer = new OpenLayers.Layer.WMS( "CoastLine",
			 "http://192.168.10.24:81/FipsMapIT/OL/map.php?",
{layers: 'Coastline', format: 'image/png' });
		map.addLayer(layer);
		map.addControl(new OpenLayers.Control.MousePosition());
		//map.setCenter(new
OpenLayers.LonLat(2074357.411583,5394835.845268), 15);
		// map.zoomToMaxExtent();
		// map.addControl( new OpenLayers.Control.LayerSwitcher() );
    </script>
  </head>
  <body onLoad="init()">
    <div id="map" class="smallmap"></div>
  </body>
</html>
Here is the main Mapfile;-
NAME Fips
STATUS ON
SIZE 600 400
SYMBOLSET /ms4w/Apache/htdocs/FipsMapIT/etc/symbols.sym
EXTENT 1089354.457600 4747978.917400 2092003.972400 6223163.821700
UNITS METERS
SHAPEPATH "/ms4w/Apache/htdocs/FipsMapIT/data"
IMAGECOLOR 255 255 255
FONTSET /ms4w/Apache/htdocs/FipsMapIT/etc/fonts.txt
CONFIG  "MS_ERRORFILE" "\ms4w\tmp\errorlog.txt"
OUTPUTFORMAT
 NAME 'AGG'
 DRIVER AGG/PNG
 IMAGEMODE RGB
 FORMATOPTION INTERLACE=OFF
END
# Start of web interface definition
WEB
  #MINSCALE 200
  #MAXSCALE 50000000
  IMAGEPATH "/ms4w/tmp/ms_tmp/"
  IMAGEURL "/ms_tmp/"
  LOG "\ms4w\tmp\log.txt"
  METADATA
    "wms_title"           "Fips"
	"wms_name"            "Fips"
	"wms_server_version"  "1.1.1"
	"wms_format"          "image/png"
	"wms_onlineresource"
    "wms_srs"             "EPSG:2193"
  END
END
# Start of reference map
REFERENCE
   IMAGE ../map/keymap.png
   EXTENT 2074357.411583 5394835.845268 2968416.907590 6735935.204660
   STATUS ON
  COLOR -1 -1 -1
  OUTLINECOLOR 255 0 0
  SIZE 120 90
END
# Start of legend
LEGEND
  KEYSIZE 18 12
  LABEL
    FONT cour
    TYPE truetype
    SIZE 8
    COLOR 0 0 0
  END
  STATUS ON
  TEMPLATE "legend.html"
END
# Start of scalebar
SCALEBAR
  IMAGECOLOR 255 255 255    LABEL
      COLOR  0 0 0
    SIZE SMALL
  END
  SIZE 400 5
  COLOR 255 255 255
  BACKGROUNDCOLOR 0 0 0
  OUTLINECOLOR 0 0 0
  UNITS kilometers
  INTERVALS 5
  STATUS ON
END
QUERYMAP
  STYLE HILITE
  COLOR 255 0 0
END
PROJECTION
	"proj=tmerc"
	"lat_0=0"
	"lon_0=173"
	"k=0.9996"
	"x_0=1600000"
	"y_0=10000000"
	"ellps=GRS80"
	"towgs84=0,0,0,0,0,0,0"
	"units=m"
	"no_defs"
END
# include "./LandUnit.map"
# include "./Transport.map"
# include "./Hydro.map"
include "./Coastline.map"
END # Map File
And here is the Coastline MapFile;-
# DBO.Coastline_NZMS260
LAYER
  NAME Coastline
  METADATA
    "DESCRIPTION"   "Coastline"
	"wms_title" "Coastline"
  END
  TYPE POLYGON
  CONNECTIONTYPE PLUGIN
  PLUGIN "/ms4w/Apache/specialplugins/msplugin_sde_92.dll"
  CONNECTION "palustris,port:5160,rnztm,XXXXXXXXXXXX,XXXXXXXXXXXXXX"
  DATA "DBO.Coastline_NZMS260,SHAPE,SDE.DEFAULT"
  PROJECTION
	"proj=tmerc"
	"lat_0=0"
	"lon_0=173"
	"k=0.9996"
	"x_0=1600000"
	"y_0=10000000"
	"ellps=GRS80"
	"units=m"
	"no_defs"
  END
  STATUS DEFAULT
  CLASS
    # MAXSCALEDENOM 2000000
    NAME "Coastline"
    SYMBOL 0
    COLOR 0 191 0
	OUTLINECOLOR 255 255 255
  END
END # Layer
Thanks heaps for you time
Neil
