[OpenLayers-Users] My map is displayed only at zoom level 0
Alexandre Dube adube at mapgears.com
Fri Feb 20 08:39:09 EST 2009
amila.maha wrote:
> Hi,
> I am trying to display a map from MapServer in OpenLayer. But it is
> displayed only when the zoom level is zero. When the zoom level is some
> other level, only a white image is shown.
> Can somebody help me with this??
> This is my javascript code segment for creating the map.
> var map_sv = new OpenLayers.Layer.MapServer( "Clouds",
> "http://localhost:7788/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/openlayer/map/wms-test.map",
> 		{layers: "clouds", isBaseLayer: "true"});
Your layer object is wrong, it should looks like this :
OpenLayers.Layer.MapServer(name, url, params, options).
"layers" is a parameter for mapserver cgi url and "isBaseLayer" is an
OpenLayers option :
    "Clouds",
    {layers: "clouds"},
    {isBaseLayer: "true"});
That might not be enough to resolve your problem but it's another fix at
least.
See the examples for more easy learning :
http://openlayers.org/dev/examples/
http://openlayers.org/dev/examples/mapserver.html
Regards,
Alexandre
> This is my map file.
> NAME "WMS-test"
> STATUS ON
> SIZE 512 256
> SYMBOLSET ../etc/symbols.sym
> EXTENT -180 -90 180 90
> UNITS METERS
> IMAGECOLOR 255 255 255
> IMAGETYPE png
> FONTSET ../etc/fonts.txt
> CONFIG "PROJ_LIB" "C:/ms4w/proj/nad/"
> WEB
>   IMAGEPATH "C:/ms4w/tmp/"
>   IMAGEURL "/ms_tmp/"
>   METADATA
>     "wms_title"     "WMS Demo Server"  ##required
>     "wms_onlineresource" "http://localhost:7788/cgi-bin/mapserv.exe?"
> ##required
>     "wms_srs"				"EPSG:42304 EPSG:42101 EPSG:4269 EPSG:4326"
>   END
> END
> PROJECTION
>   "init=epsg:42304"   ##required
> END
> # Start of layer definitions
> LAYER
>  NAME clouds
>  METADATA
>     "wms_title"    "Clouds"   ##required
>   END
>  TYPE RASTER
>  STATUS ON
>  PROJECTION
>     "init=epsg:42304"   ##recommended
>  END
>  DATA "../data/test/day_clouds.tif"
> END
> END # Map File
Alexandre Dubé
Mapgears
www.mapgears.com
