[OpenLayers-Users] Drag events on the map not firing
Joao Duarte
joao.c.duarte at co.sapo.pt
Thu Feb 26 09:41:26 EST 2009
Hi list,
I noticed that the drag events (dragstart, dragend, drag) are not being
fired by the map, although they are documented as working.
Is this a known issue?
Another strange thing is the setCenter map method. It receives a Boolean
dragging parameter which specifies if the movestart/end events should be
fired. If the parameter name is dragging shouldnt be the drag events fired
instead of move?
Best Regards,
João Duarte,
Sapo Maps <http://maps.sapo.pt> http://maps.sapo.pt
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090226/19158c5b/attachment.html
