[OpenLayers-Users] Drag events on the map not firing
Christopher Schmidt
crschmidt at metacarta.com
Thu Feb 26 09:59:41 EST 2009
On Thu, Feb 26, 2009 at 02:41:26PM +0000, Joao Duarte wrote:
> Hi list,
> I noticed that the drag events (dragstart, dragend, drag) are not being
> fired by the map, although they are documented as working.
These events have never really existed; they are best ignored, and
should probably be removed from many applicable documentation.
> Another strange thing is the setCenter map method. It receives a Boolean
> dragging parameter which specifies if the movestart/end events should be
> fired. If the parameter name is dragging shouldnt be the drag events fired
> instead of move?
It is best to consider the drag events as completely nonexistent.
Regards,
Christopher Schmidt
MetaCarta
