[OpenLayers-Users] Layer.Vector with multiple data sources
Arnd Wippermann arnd.wippermann at web.de
Fri Jan 9 12:54:16 EST 2009
Thanks
Now it works as expected
Arnd Wippermann
-----Ursprüngliche Nachricht-----
Von: andreas.hocevar at gmail.com [mailto:andreas.hocevar at gmail.com] Im Auftrag
von Andreas Hocevar
Gesendet: Freitag, 9. Januar 2009 16:23
An: Arnd Wippermann
Cc: users at openlayers.org
Betreff: Re: [OpenLayers-Users] Layer.Vector with multiple data sources
Arnd,
On Fri, Jan 9, 2009 at 2:37 PM, Arnd Wippermann <arnd.wippermann at web.de>
wrote:
> I have no luck so far.
> The following code is from the example styles-context.html, added the
> getVisibility. If you paste the code into firebug console for the
> openlayers homepage http://openlayers.org/, it will add a vector layer
> with points. At zoomLevel 0 the red points are set to display:"none", etc.
> But you can see, that the display property have no effect. Do I miss
> something?
On the contrary! You have found a bug. See
http://trac.openlayers.org/ticket/1898 for a fix.
Regards,
Andreas.
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
