[OpenLayers-Users] Projection problem
Christopher Schmidt
crschmidt at metacarta.com
Tue Jan 20 11:27:26 EST 2009
On Tue, Jan 20, 2009 at 05:15:10PM +0100, David Martinez Morata wrote:
> All My layers are
> "PROJECTION
> "init=epsg:27572"
> END"
> definition in the mapfile
> And the MAP object have the same definition.
> It's for this I put the value in var georoute definition
> "reproject": true,
> in the var options for Openlayers map I define this
> var options = {numZoomLevels: 30,
> projection: new OpenLayers.Projection("EPSG:900913"),
> displayProjection: new OpenLayers.Projection("EPSG:4326"),
> units: "m",
> maxResolution: 156543.0339,
> maxExtent: new OpenLayers.Bounds(-20037508, -20037508, 20037508,
> 20037508.34)};
You're requesting the map tiles to be in EPSG:900913. EPSG:900913 is not
an option in your wms_srs metadata, so the MapServer can't serve tiles
inthat projection. If you want to use that projection, add it to
wms_srs.
Regards,
Christopher Schmidt
MetaCarta
