[OpenLayers-Users] problems with ArcGIS Server 9.3 and sld
Parameter
bartvde at osgis.nl
bartvde at osgis.nl
Tue Jan 27 09:47:51 EST 2009
I have experienced the same problem, but the cause is likely on the ESRI
side. I have found no solution as yet, except DCOM errors on the Windows
machine that runs ArcGIS Server. So it might have problems launching the
MSXML parser.
Best regards,
Bart
> Hello list,
> Perhaps somebody can help me. I use the ESRI ArcServer 9.3 software. There
> I have realise a wms. Now I will show this wms with openlayers.
> I make it like this:
> var map = new OpenLayers.Map('map',options1);
> var wms = new
> OpenLayers.Layer.WMS("Gemeinden","http://servername.ch:8399/arcgis/services/GINES/MapServer/WMSServer?",
> {layers:"0"},{singleTile: true, ratio:1} );
> map.addLayer(wms);
> // var
> sld_string=url+"jahr="+jahr+"&indikator="+indikator1+"&klassen="+klassen+"&vis="+vis1;
> var sld_string=http://localhost/GINES_Daten_BE/test.sld;
> // wms.mergeNewParams({ SLD:sld_string });
> map.zoomToMaxExtent();
> If I only show the map all works fine. But now I try to use a sld file
> (see var sld_string and mergeNewParams). It doesn't work. I always get the
> message: "parser failed"
> What can I do to make it work? Can somebody help me?
> Thank you a lot for your help.
> Greetings Hanno Rahn
> Hanno Rahn, Dipl.-Ing. (FH) Geoinformatik
> ZHAW Zürcher Hochschule für Angewandte Wissenschaften Umwelt und
> Natürliche Ressourcen
> Fachstelle Geoinformatik
> Grüental, Postfach CH-8820 Wädenswil
> Tel +41 (0)58 934 5592
> Fax +41 (0)58 934 5580
> hanno.rahn at zhaw.ch
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
