[OpenLayers-Users] REPEAT QUESTION - How do I prevent my map from zooming out too far?
jim.meyer at concept-solutions.com jim.meyer at concept-solutions.com
Mon Jul 20 16:48:35 EDT 2009
Hi Andres,
   It looks like using a scales array did the trick.
   My values were... scales: [153000000, 77000000, 38000000, 19000000,
10000000, 5000000, 2000000, 1000000, 599000, 300000],
Thanks,
Jim
James B. Meyer
Java Programmer
Concept Solutions, Inc.
(703) 472-7838
11600 Sunrise Valley Drive
Suite 300
Reston, VA 20191
-----Original Message-----
From: andreas.hocevar at gmail.com [mailto:andreas.hocevar at gmail.com] On Behalf
Of Andreas Hocevar
Sent: Monday, July 20, 2009 3:22 PM
To: jim.meyer at concept-solutions.com
Cc: users at openlayers.org
Subject: Re: [OpenLayers-Users] REPEAT QUESTION - How do I prevent my map
there are many ways to do that, combine one or more of the options
below to achieve the result you need:
 * set a maxExtent for your base layer
 * set a maxResolution for the base layer,
 * configure a resolutions or scales array for your base layer
Regards,
Andreas.
On Mon, Jul 20, 2009 at 9:05 PM, <jim.meyer at concept-solutions.com> wrote:
> Hi everyone,
>    I had asked this question originally on June 29, 2009 and didn’t
receive
> a response
>    Currently when I zoom out to the fullest extent available on the
> panzoombar my map shows four copies of the earth.  Is there an easy way to
> prevent this from happening?
>    It seems that using a ‘singleTile’ value set to true will do it.  But,
> I’d prefer to continue to rely upon tiled images.  Are there any other
ideas
> out there?
> Thanks,
> Jim
> James B. Meyer
> Java Programmer
> (703) 472-7838
> Suite 300
> Reston, VA 20191
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
