[OpenLayers-Users] Example of creating a POI with attributes
Alexandre Dube
adube at mapgears.com
Tue Jun 2 09:05:46 EDT 2009
Hi Stephen,
Here's an old demo I made demonstrating creation/modification/deletion
of line features (1). The highlight and display popup is done by a
custom "HighlightFeature" control but with OpenLayers 2.8 you can
achieve this with the SelectFeature control instead.
Hope this helps,
Alexandre
(1) http://dev4.mapgears.com/bdga/bdgaWFS-T.html
Stephen Woodbridge wrote:
> Hi all,
> Does anyone have a public page/example that demonstrates creating a
> point feature and adding text attributes to it? This seems like it would
> be a common use case.
> Creating the vector feature is straight forward. It would be nice if
> after you create the point, that you could click it and open a balloon
> with fields that you could fill in and a save|cancel button that would
> save it back to the server.
> Maybe this is two operations:
> 1) create or drag the marker for editing the location
> 2) click to edit attributes or to delete marker
> Mostly unsure on the attributes and the best way to glue all this together.
> Suggestions and examples would be helpful.
> Thanks,
> -Steve
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Alexandre Dubé
Mapgears
www.mapgears.com
