[OpenLayers-Users] Error displaying map in IE8 - VML.js
Andreas Hocevar ahocevar at opengeo.org
Fri Jun 12 10:59:33 EDT 2009
I can confirm that IE7 in standards compliant mode does not render
labels - with or without the patch. So that is a separate issue, and I
created http://trac.openlayers.org/ticket/2135 to track it.
Regards,
Andreas.
On Fri, Jun 12, 2009 at 4:23 PM, Mike Adair<madair at dmsolutions.ca> wrote:
> I'm testing with that patch in the application I'm currently working on
> and for the most part it is a big improvement.  The one remaining issue
> I'm seeing is feature labels don't show up in IE7 with the document in
> IE7 standards mode.  Labels do show up in IE7 in quirks mode though.
> (Isn't it wonderful that IE gives us so many combinations to screw up
> with ...)
> Even so, I would urge this patch get into 2.8 because it is a bug with
> existing code, the patch fixes most of the issue and we know there will
> be many questions on the lists about it if it doesn't go in.
> Mike
> Christopher Schmidt wrote:
>> On Fri, Jun 12, 2009 at 03:52:54PM +0200, Asle Benoni wrote:
>>> Thanks Kenneth, the compatibility hack works fine. I would rather not hack
>>> VML.js but I see this hack is newer than the one I tried. As long as the
>>> quickfix works I am satisfied. But would like to know if some have success
>>> with it and if it is included in future OL release.
>> It can't be included in a future OL release until people test it. If
>> you're unwilling to test it, the chances it will be included decrease.
>> Please help test it if you care about it.
>> -- Chris
>>> /asle
>>> 2009/6/12 Andreas Hocevar <ahocevar at opengeo.org>
>>>> Hi,
>>>> On Fri, Jun 12, 2009 at 8:53 AM, Kenneth Skovhede, GEOGRAF
>>>> A/S<ks at geograf.dk> wrote:
>>>>> Note sure what the actual problem is, but there are notes that the patch
>>>>> does not solve all issues.
>>>>> There is a nother fix mentioned, namely the one in comment #20:
>>>>> http://trac.openlayers.org/ticket/1910#comment:20
>>>>> This effectively places IE8 in IE7 compatibility mode, and it works.
>>>>> Although it's not the correct long term solution, you can use it until
>>>>> the issue is fixed more permanently.
>>>> The latest patch [1] should fix all vector layer issues in IE8. It
>>>> would be nice to get some feedback if this is really the case.
>>>> Regards,
>>>> Andreas.
>>>> [1]
>>>> http://trac.openlayers.org/attachment/ticket/1910/openlayers-1910.patch
>>>> Andreas Hocevar
>>>> OpenGeo - http://opengeo.org/
>>>> Expert service straight from the developers.
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
>   Michael Adair
>   Senior Software Architect
>   DM Solutions Group Inc.
>   Office: (613) 565-5056 x26
>   http://www.dmsolutions.ca
>   http://research.dmsolutions.ca
> Users mailing list
Andreas Hocevar
