[OpenLayers-Users] Error displaying map in IE8 - VML.js
Mike Adair
madair at dmsolutions.ca
Fri Jun 12 10:23:16 EDT 2009
I'm testing with that patch in the application I'm currently working on
and for the most part it is a big improvement. The one remaining issue
I'm seeing is feature labels don't show up in IE7 with the document in
IE7 standards mode. Labels do show up in IE7 in quirks mode though.
(Isn't it wonderful that IE gives us so many combinations to screw up
with ...)
Even so, I would urge this patch get into 2.8 because it is a bug with
existing code, the patch fixes most of the issue and we know there will
be many questions on the lists about it if it doesn't go in.
Mike
Christopher Schmidt wrote:
> On Fri, Jun 12, 2009 at 03:52:54PM +0200, Asle Benoni wrote:
>> Thanks Kenneth, the compatibility hack works fine. I would rather not hack
>> VML.js but I see this hack is newer than the one I tried. As long as the
>> quickfix works I am satisfied. But would like to know if some have success
>> with it and if it is included in future OL release.
> It can't be included in a future OL release until people test it. If
> you're unwilling to test it, the chances it will be included decrease.
> Please help test it if you care about it.
> -- Chris
>> /asle
>> 2009/6/12 Andreas Hocevar <ahocevar at opengeo.org>
>>> Hi,
>>> On Fri, Jun 12, 2009 at 8:53 AM, Kenneth Skovhede, GEOGRAF
>>> A/S<ks at geograf.dk> wrote:
>>>> Note sure what the actual problem is, but there are notes that the patch
>>>> does not solve all issues.
>>>> There is a nother fix mentioned, namely the one in comment #20:
>>>> http://trac.openlayers.org/ticket/1910#comment:20
>>>> This effectively places IE8 in IE7 compatibility mode, and it works.
>>>> Although it's not the correct long term solution, you can use it until
>>>> the issue is fixed more permanently.
>>> The latest patch [1] should fix all vector layer issues in IE8. It
>>> would be nice to get some feedback if this is really the case.
>>> Regards,
>>> Andreas.
>>> [1]
>>> http://trac.openlayers.org/attachment/ticket/1910/openlayers-1910.patch
>>> Andreas Hocevar
>>> OpenGeo - http://opengeo.org/
>>> Expert service straight from the developers.
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
Michael Adair
Senior Software Architect
DM Solutions Group Inc.
Office: (613) 565-5056 x26
http://www.dmsolutions.ca
http://research.dmsolutions.ca
