[OpenLayers-Users] Impossible reproject wfs layer
Micho Gar michogar at gmail.com
Mon Jun 29 14:36:56 EDT 2009
Hi all,
I was searching in the list something about my problem. I can not reproject
my wfs layer over my OpenStreetMaps layer with spherical mercator. I use
this code:
function initMap(){
    format = 'image/png';
    if (initBounds == null) initBounds = new
OpenLayers.Bounds(-18785164.068, -11740727.3725,
            18785164.068, 11740727.7125);
    var bounds = new OpenLayers.Bounds(-20037508, -20037508,
            20037508, 20037508.34);
    var proj4326 = new OpenLayers.Projection("EPSG:4326");
    var proj900913 = new OpenLayers.Projection("EPSG:900913");
    //initBounds.transform(proj4326, proj900913);
    var options = {
            controls: [],
            maxExtent: bounds,
            maxResolution: 39135.758475,
            numZoomLevels: 19,
            projection: proj900913,
            displayProjection: proj4326,
            units: 'm'
    map = new OpenLayers.Map('map',options);
    //carga las capas de Google en caso de que se vayan a utilizar
    /*var gmap = new OpenLayers.Layer.Google(
            "Google Streets", {'sphericalMercator': true}
    var gsat = new OpenLayers.Layer.Google(
            "Google Satellite",
            {type: G_SATELLITE_MAP, 'sphericalMercator': true,
numZoomLevels: 18}
    //carga la capa base de OSM
    var OSMLayer = new OpenLayers.Layer.OSM.Osmarender("Osmarender");
    var MapnikLayer = new OpenLayers.Layer.OSM.Mapnik("Mapnik");
    // carga capas wms
    var Instancias  = new OpenLayers.Layer.WMS(
            "Instancias", "http://localhost:8080/geoserver/wms",
                layers: 'osmius:usuarios_instancias',
                srs: 'EPSG:4326',
                format: format,
                transparent : 'true'//,
            {singleTile: true, ratio: 1}
    var Servicios = new OpenLayers.Layer.WMS(
            "Servicios", "http://localhost:8080/geoserver/wms",
                layers: 'osmius:usuarios_servicios',
                srs: 'EPSG:4326',
                format: format,
    var WFSlayer = new OpenLayers.Layer.WFS( "Instancias WFS",
            "http://localhost:8080/geoserver/wfs",
            { typename: 'osmius:usuarios_instancias'},
                typename: 'usuarios_instancias',
                projection: map.displayProjection
You can see that I use the projection parameter in the wfs layer, but the
features are not reprojected, I don't understand because.
This is my capabilities:
<FeatureType>
<Name>osmius:usuarios_instancias</Name>
<Title>osm_vw_instance_pnt_Type</Title>
<Abstract>Generated from osmius</Abstract>
<ows:Keywords>
<ows:Keyword>osm_vw_instance_pnt</ows:Keyword>
<ows:Keyword>osmius</ows:Keyword>
</ows:Keywords>
<DefaultSRS>urn:x-ogc:def:crs:EPSG:4326</DefaultSRS>
<ows:WGS84BoundingBox>
<ows:LowerCorner>-9.648588334999998 40.30276938</ows:LowerCorner>
<ows:UpperCorner>0.4904789049999987 50.44183662</ows:UpperCorner>
</ows:WGS84BoundingBox>
</FeatureType>
<FeatureType>
<Name>osmius:usuarios_servicios</Name>
<Title>osm_vw_service_pnt_Type</Title>
<ows:Keywords>
<ows:Keyword>osm_vw_service_pnt</ows:Keyword>
</ows:Keywords>
<ows:LowerCorner>-3.813766 40.382172</ows:LowerCorner>
<ows:UpperCorner>-3.613766 40.582172</ows:UpperCorner>
</FeatureType>
</FeatureTypeList>
Thanks to all
# michogar
# Analista Programador SIG
# GNU/Linux Counter 462666
Una visión personal:
http://michogar.blogspot.com
El día a día:
http://twitter.com/michogar
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090629/47fd9edf/attachment.html
