[OpenLayers-Users] Problems implementing WFS
Alexandre Dube adube at mapgears.com
Tue Jun 30 08:00:13 EDT 2009
Hi Hugo,
  This looks like a feature namespace problem.  See the Format.XML
readNode function, put a break point at line :
var group = this.readers[this.namespaceAlias[node.namespaceURI]];
  This might be the problem,
Alexandre
Hugo wrote:
> Hello all,
> I'm having troubles to implement a vector layer with WFS protocol.
> From firebug i can see that the attributes from the layer are
> extracted, however no vector feature is displayed in the map.
> DO you have any suggestions??? My code is as follows:
> var saveStrategy = new OpenLayers.Strategy.Save();
>         var wfs2 = new OpenLayers.Layer.Vector(
>             "ExplorWFS2",
>                 strategies: [new OpenLayers.Strategy.BBOX(),
> saveStrategy],
>                 projection: wgs,
>                 protocol: new OpenLayers.Protocol.WFS({
>                     version: "1.1.0",
>                     srsName: "EPSG:4326",
>                     url: "http://isegi.dyndns.org:8080/geoserver/wfs?",
>                     featureNS :  "http://isegi.dyndns.org:8080/sigla",
>                     featureType: "explor",
>                     geometryName: "the_geom",
>                     schema:
> "http://isegi.dyndns.org:8080/geoserver/wfs/DescribeFeatureType?version=1.1.0&typename=sigla:explor
> <http://isegi.dyndns.org:8080/geoserver/wfs/DescribeFeatureType?version=1.1.0&typename=sigla:explor>",
>                     format: new OpenLayers.Format.WFST.v1_1_0({
>                         featureType: 'explor',
>                         featureNS: "http://isegi.dyndns.org:8080/sigla",
>                         featurePrefix: 'sigla',
>                         geometryName: 'the_geom'
> I have tried these code with and without the format option.
> If i simply use the following code, everything goes perfect and vector
> features are displayed in the map:
> var wfs = new OpenLayers.Layer.WFS(
>             "ExplorWFS",
>             {typename: 'sigla:explor'},
>                 featureVersion: "1.0.0",
>                 typename: 'explor',
>                 featureNS: '"http://isegi.dyndns.org:8080/sigla',
>                 projection: wgs,
>                 extractAttributes: true,
>                 schema:
> Thanks in advance.
> Kind regards,
> Hugo Martins
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Alexandre Dubé
Mapgears
www.mapgears.com
