[OpenLayers-Users] IE7 vector rendering error
Eric Lemoine eric.lemoine at camptocamp.com
Wed Sep 2 01:40:51 EDT 2009
On Tuesday, September 1, 2009, Jo Cook <j.cook at oxfordarch.co.uk> wrote:
> Dear All,
> I am using revision 9635 of openlayers (via the MapFish svn), and have just
> created a single file library for openlayers to speed up this page:
> http://mapdata.thehumanjourney.net/vgswandb_new.html
> In IE7 (either using IETab or genuinely using IE7) I get the error "Your
> browser does not support vector rendering. Currently supported renderers
> are: SVG VML Canvas". This error occurs when the page is originally loaded,
> and when you try and select a feature (by dragging a box around it), nothing
> happens instead of it being highlighted and showing feature information as
> it is supposed to.
> Previously I have had this error when trying to use the library.cfg file to
> create my single file library, and I fixed it by adding lots of additional
> includes,  but this time I went for the full.cfg file instead, and still
> have the error. A search of the mailing lists suggests this problem used to
> occur in earlier releases, but should now be fixed.
> I have tested this page with the original multi-file version of OpenLayers
> and it does not occur.
Hi.
VML.js is most probably not included in the built file. Edit the built
file and search for "OpenLayers.Renderer.VML = OpenLayers.Class" to
check that.
Cheers,
> Thanks
> Jo
> View this message in context: http://n2.nabble.com/IE7-vector-rendering-error-tp3561507p3561507.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
