[OpenLayers-Users] IE7 vector rendering error
Jo Cook j.cook at oxfordarch.co.uk
Tue Sep 1 12:06:42 EDT 2009
Dear All,
I am using revision 9635 of openlayers (via the MapFish svn), and have just
created a single file library for openlayers to speed up this page:
http://mapdata.thehumanjourney.net/vgswandb_new.html
In IE7 (either using IETab or genuinely using IE7) I get the error "Your
browser does not support vector rendering. Currently supported renderers
are: SVG VML Canvas". This error occurs when the page is originally loaded,
and when you try and select a feature (by dragging a box around it), nothing
happens instead of it being highlighted and showing feature information as
it is supposed to.
Previously I have had this error when trying to use the library.cfg file to
create my single file library, and I fixed it by adding lots of additional
includes,  but this time I went for the full.cfg file instead, and still
have the error. A search of the mailing lists suggests this problem used to
occur in earlier releases, but should now be fixed.
I have tested this page with the original multi-file version of OpenLayers
and it does not occur.
Thanks
Jo
View this message in context: http://n2.nabble.com/IE7-vector-rendering-error-tp3561507p3561507.html
