[OpenLayers-Users] Google Map layers no longer works !
Andreas Hocevar ahocevar at opengeo.org
Thu Sep 3 03:51:24 EDT 2009
can you please point to urls where you are experiencing this problem? I
just tried http://openlayers.org/dev/examples/spherical-mercator.html
and http://openlayers.org/dev/examples/spherial-mercator.html, and both
work fine.
Also, in your own applications, make sure that you are using v2 of the
API, because v3 is not supported by OpenLayers. The script to include is
http://maps.google.com/maps?file=api&amp;v=2&amp;key=<your_key_here>
If the v3 API is a requirement, patches or funding are always welcome :-).
Regards,
Andreas.
bdtyah wrote:
> Hi all,
> It seems that OpenLayers don't works with the new Google Maps Api.
> Google Maps layers no longer displays (see Openlayers examples).
> Firebug reports that G_NORMAL_MAP, G_SATELLITE_MAP and G_HYBRID_MAP are not
> defined.
> Any help about this (serious) problem ?
> Thanks
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
