[OpenLayers-Users] Google Map layers no longer works !
bdtyah bdtyah at yahoo.fr
Thu Sep 3 09:34:03 EDT 2009
You are right Andreas,
It seems that was a ISP DNS problem.
If I change the internet connection, every things works right
Thanks a lot
Andreas Hocevar-2 wrote:
> Hi,
> can you please point to urls where you are experiencing this problem? I
> just tried http://openlayers.org/dev/examples/spherical-mercator.html
> and http://openlayers.org/dev/examples/spherial-mercator.html, and both
> work fine.
> Also, in your own applications, make sure that you are using v2 of the
> API, because v3 is not supported by OpenLayers. The script to include is
> http://maps.google.com/maps?file=api&amp;v=2&amp;key=<your_key_here>
> If the v3 API is a requirement, patches or funding are always welcome :-).
> Regards,
> Andreas.
> bdtyah wrote:
>> Hi all,
>> It seems that OpenLayers don't works with the new Google Maps Api.
>> Google Maps layers no longer displays (see Openlayers examples).
>> Firebug reports that G_NORMAL_MAP, G_SATELLITE_MAP and G_HYBRID_MAP are
>> not
>> defined.
>> Any help about this (serious) problem ?
>> Thanks
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://n2.nabble.com/Google-Map-layers-no-longer-works-tp3570991p3573217.html
