[OpenLayers-Users] mouse event return clicked layer
gustavo palminha gustavopalminha at hotmail.com
Fri Sep 4 21:01:19 EDT 2009
Hy there.
First of all let me say nice webgis, realy good those menus are well made.
After testing your browser, i pressed the (i) button with the tool tip
troggle query and i click on the map, then i got asp for download, after
download it got xml code with the message " WMS server error. Invalid
layer(s) given in the LAYERS parameter".
It looks like your tool has some work left to do, but all in all everything
was great.
Congratulations.
Regards.
Arnd Wippermann wrote:
> Hi,
> I have to set the active layer for the map to reference that layer
> afterwards with a mouse click.
> http://gis.ibbeck.de/ginfo/apps/OL27Client/OL27ClientGis.asp?WMC=./data/WMC/
> !Google_World.wmc.xml
> Arnd
> -----Ursprüngliche Nachricht-----
> Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
> Auftrag von gustavo palminha
> Gesendet: Freitag, 4. September 2009 19:58
> An: users at openlayers.org
> Betreff: Re: [OpenLayers-Users] mouse event return clicked layer
> Hello.
> As you say "....set opacity or remove layer."
> But the idea would be to reference that layer with a click on the map.
> Do you do that?
> And if so how?
> Regards.
> GP
>> Hi,
>> I use in my application the possibility to set the active layer for
>> the map.
>> With this I am able to accomplish general functions like set opacity
>> or remove layer.
>> And I can decide, which special functions are possible for this layer.
>> I.e.
>> if it is WMS layer, i can do a GetFeatureInfo request for that layer,
>> if it is a vector layer I can display a editing toolbar.
>> Arnd
>> [mailto:users-bounces at openlayers.org] Im Auftrag von gustavo palminha
>> Gesendet: Freitag, 4. September 2009 16:32
>> After studying the GetFeatureInfo example from openlayers i looked
>> into the WSDL of the WMS server that was used for building the
>> example.
>> After looking into it there was references in the WSDL about the
>> GetFeatureInfo. After a short look into the foruns about the
>> GetFeatureInfo i had the feeling that there a few stet to acomplish
>> this, so whats called with a fewlines of code from the OL requires a
>> server setup (Mapserver or
>> Geoserver) to be able to retrieve back the information.
>> I will try to find a alternative solution to my application.
>> I was just curious if there was any way to retrive back the name of
>> the WMS clicked layer, because thats the only thing i need so far, the
>> rest is done.
>> Regards.
>> Andreas Hocevar-2 wrote:
>>> gustavo palminha wrote:
>>>> Hello andreas.
>>>> I bottom line is that i would like to create a sort of
>>>> GetFeatureInfo for my WMS layers.
>>>> I do not use mapserver or geoserver, instead i use manifold gis
>>>> which doen not provide a valid WSDL for a working GetFeatureInfo.
>>> Wow, I was not aware that there is a SOAP-based flavour of
>>> GetFeatureInfo that requires a WSDL. I think your point is that
>>> Manifold does not support GetFeatureInfo [1].
>>>> So my main goal would be to know how to discover a way to capture
>>>> the name of the clicked wms layer.
>>>> Assuming that this is not possible i was thinking about doing this:
>>>> OL Side (client side)
>>>> •Build a list of shown/active layers (by reading the layers on the
>>>> layser selection menu) •Pass this list to a webservice with the x,y
>>>> Server Side (webservice) •Filter them excluding the ones from the
>>>> list where they did not touch/intersect the x/y •Read back the items
>>>> retrieved and the user should have pressed the last layer in the
>>>> list.
>>> This sounds like re-inventing the wheel. See [1] for suggestions on
>>> how to work around this. You could also contact Manifold support and
>>> suggest they add GetFeatureInfo (hey, you paid for that software), or
>>> replace Manifold with some GetFeatureInfo capable WMS like Geoserver
>>> or UMN Mapserver.
>>> Regards,
>>> Andreas.
>>> [1] http://forum.manifold.net/forum/t82857.12
>>> Andreas Hocevar
>>> OpenGeo - http://opengeo.org/
>>> Expert service straight from the developers.
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
>> Regards.
>> GP
>> View this message in context:
>> http://n2.nabble.com/mouse-event-return-clicked-layer-tp3579125p358032
>> 7.html Sent from the OpenLayers Users mailing list archive at
>> Nabble.com.
>> Users mailing list
>> Users mailing list
> Regards.
> GP
> http://n2.nabble.com/mouse-event-return-clicked-layer-tp3579125p3581539.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users mailing list
Regards.
GP
View this message in context: http://n2.nabble.com/mouse-event-return-clicked-layer-tp3579125p3583340.html
