[OpenLayers-Users] Layer from GML loading only for the first time
sunny74 sb.ray at hotmail.com
Mon Sep 7 07:28:38 EDT 2009
Thanks for your reply.
So how to do the following:
1) change the cache
settings on your webserver for the XML1 subdir (tell the browser to never
cache the file)?
2) append a random number to the url?
Pls tell in details.
Regards.
Bart van den Eijnden (OSGIS)-2 wrote:
> Hi,
> you are probably running into browser cache. So either change the cache
> cache the file), or append a random number to the url.
> Best regards,
> Bart
>> Dear Friends,
>> I am having a query builder which allows an user to select one feature at
>> a
>> time.
>> The geometry for this feature is then populated into a GML file format
>> using
>> another xml.
>> So every time an user selects one feature the GML file is deleted and a
>> new
>> one created with the geometry of the new feature.
>> Although GML file is created with every change in selection Openlayers is
>> unable to load the changed GML and show it on the map.
>> So openlayers is able to display the data from the GML for the first time
>> only. So from second and subsequent selection it shows only the first
>> feature on the map.
>> The code is:
>> map.addLayer(new OpenLayers.Layer.GML('choice_features',
>> "XML1/FeatureGML.xml"));
>> Is it a bug?
>> If not how to tackle the problem.
>> Thanks in advance.
>> View this message in context:
>> http://n2.nabble.com/Layer-from-GML-loading-only-for-the-first-time-tp3596382p3596382.html
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Users mailing list
View this message in context: http://n2.nabble.com/Layer-from-GML-loading-only-for-the-first-time-tp3596382p3596762.html
