[OpenLayers-Users] Layer from GML loading only for the first time
sunny74 sb.ray at hotmail.com
Mon Sep 7 14:32:12 EDT 2009
Thanks for your reply.
I am afraid I have not understood the solution suggested by you.
You are saying to use the setURL to change the url for a gml layer after
layer creation.
Does that mean the following code:
map.addLayer(new OpenLayers.Layer.GML('choice_features',
 "XML1/FeatureGML.xml"))
after the creation of the above layer I use the setURL as below:
choice_features.setUrl("http://....");
Do i give just the Url for the GML file or do i need to add some random
number to it at the end.
Then  how do I load the above Url.
Regards.
Arnd Wippermann wrote:
> Hi,
> So far I rembember, there is a function setUrl to change the url for a gml
> layer after layer creation. And also you link to the same as previous, the
> new data will displayed.
> So you don't need to add-remove-add your layer to display new data from a
> GML vectorlayer.
> yourLayer.setUrl("http://...."); should do the trick.
> Arnd
> -----Ursprüngliche Nachricht-----
> Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
> Auftrag von sunny74
> Gesendet: Montag, 7. September 2009 13:29
> An: users at openlayers.org
> Betreff: Re: [OpenLayers-Users] Layer from GML loading only for the first
> time
> Hi,
> So how to do the following:
> 1) change the cache
> settings on your webserver for the XML1 subdir (tell the browser to never
> cache the file)?
> 2) append a random number to the url?
> Pls tell in details.
> Regards.
> Bart van den Eijnden (OSGIS)-2 wrote:
>> Hi,
>> you are probably running into browser cache. So either change the
>> cache settings on your webserver for the XML1 subdir (tell the browser
>> to never cache the file), or append a random number to the url.
>> Best regards,
>> Bart
>>> Dear Friends,
>>> I am having a query builder which allows an user to select one
>>> feature at a time.
>>> The geometry for this feature is then populated into a GML file
>>> format using another xml.
>>> So every time an user selects one feature the GML file is deleted and
>>> a new one created with the geometry of the new feature.
>>> Although GML file is created with every change in selection
>>> Openlayers is unable to load the changed GML and show it on the map.
>>> So openlayers is able to display the data from the GML for the first
>>> time only. So from second and subsequent selection it shows only the
>>> first feature on the map.
>>> The code is:
>>> "XML1/FeatureGML.xml"));
>>> Is it a bug?
>>> If not how to tackle the problem.
>>> Thanks in advance.
>>> View this message in context:
>>> http://n2.nabble.com/Layer-from-GML-loading-only-for-the-first-time-t
>>> p3596382p3596382.html Sent from the OpenLayers Users mailing list
>>> archive at Nabble.com.
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
>> Users mailing list
> http://n2.nabble.com/Layer-from-GML-loading-only-for-the-first-time-tp359638
> 2p3596762.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users mailing list
View this message in context: http://n2.nabble.com/Layer-from-GML-loading-only-for-the-first-time-tp3596382p3598816.html
