[OpenLayers-Users] Layer from GML loading only for the first time
Arnd Wippermann arnd.wippermann at web.de
Mon Sep 7 12:23:18 EDT 2009
So far I rembember, there is a function setUrl to change the url for a gml
layer after layer creation. And also you link to the same as previous, the
new data will displayed.
So you don't need to add-remove-add your layer to display new data from a
GML vectorlayer.
yourLayer.setUrl("http://...."); should do the trick.
Arnd
-----Ursprüngliche Nachricht-----
Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
Auftrag von sunny74
Gesendet: Montag, 7. September 2009 13:29
An: users at openlayers.org
Betreff: Re: [OpenLayers-Users] Layer from GML loading only for the first
time
Thanks for your reply.
So how to do the following:
1) change the cache
settings on your webserver for the XML1 subdir (tell the browser to never
cache the file)?
2) append a random number to the url?
Pls tell in details.
Regards.
Bart van den Eijnden (OSGIS)-2 wrote:
> Hi,
> you are probably running into browser cache. So either change the
> cache settings on your webserver for the XML1 subdir (tell the browser
> to never cache the file), or append a random number to the url.
> Best regards,
> Bart
>> Dear Friends,
>> I am having a query builder which allows an user to select one
>> feature at a time.
>> The geometry for this feature is then populated into a GML file
>> format using another xml.
>> So every time an user selects one feature the GML file is deleted and
>> a new one created with the geometry of the new feature.
>> Although GML file is created with every change in selection
>> Openlayers is unable to load the changed GML and show it on the map.
>> So openlayers is able to display the data from the GML for the first
>> time only. So from second and subsequent selection it shows only the
>> first feature on the map.
>> The code is:
>> map.addLayer(new OpenLayers.Layer.GML('choice_features',
>> "XML1/FeatureGML.xml"));
>> Is it a bug?
>> If not how to tackle the problem.
>> Thanks in advance.
>> View this message in context:
>> http://n2.nabble.com/Layer-from-GML-loading-only-for-the-first-time-t
>> p3596382p3596382.html Sent from the OpenLayers Users mailing list
>> archive at Nabble.com.
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Users mailing list
http://n2.nabble.com/Layer-from-GML-loading-only-for-the-first-time-tp359638
2p3596762.html
Users mailing list
