[OpenLayers-Users] Problems using custom symbols (graphic-name) on IE8 by adding objects to OpenLayers.Renderer.symbol
Philip Bruvoll pbruvoll at hotmail.com
Tue Sep 8 08:05:00 EDT 2009
Thanks you for the answer.
Is there a OpenLayers.js that contains this patch? (I'm using the single file version).
I tried http://dev.openlayers.org/nightly/OpenLayers.js but the bug is still there.
Also, would I need to apply all the patches at http://trac.openlayers.org/ticket/1836 or just one of them?
Kind regards,
Philip Bruvoll
> Date: Tue, 8 Sep 2009 10:58:56 +0200
> From: ahocevar at opengeo.org
> To: pbruvoll at hotmail.com
> CC: users at openlayers.org
> Subject: Re: [OpenLayers-Users] Problems using custom symbols (graphic-name) on IE8 by adding objects to OpenLayers.Renderer.symbol
> Philip Bruvoll wrote:
> > Hi,
> > I'm having some trouble making custom symbols i IE8. I'm following the
> > example at http://openlayers.org/dev/examples/graphic-name.html
> > If i substitute line 11 (OpenLayers.Renderer.symbol.rectangle = [2,0,
> > 4,5, 0,5, 2,0];)
> > with OpenLayers.Renderer.symbol.rectangle = [0.5,0, 10,8, 0,8, 0.5,0]; or
> > OpenLayers.Renderer.symbol.rectangle = [2,0, 4,5, 0,5, 2,0];
> > the symbol will display correctly in Firefox but not in IE8.
> > Does anyone know why this happens?
> You are most likely running into http://trac.openlayers.org/ticket/1836
> Apply the latest patch from that ticket, and it should work.
> Regards,
> Andreas.
> > Kind regards,
> > Philip Bruvoll
> > Share your memories online with anyone you want anyone you want.
> > <http://www.microsoft.com/middleeast/windows/windowslive/products/photos-share.aspx?tab=1>
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
_________________________________________________________________
Share your memories online with anyone you want.
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090908/43e3c8fa/attachment.html
