[OpenLayers-Users] Layer visibility problem
sunny74 sb.ray at hotmail.com
Wed Sep 9 05:15:16 EDT 2009
Dear Friends,
I am now loading the layers in groups instead of individually.
First I am loading the base layer followed by 4 groups of layers, first
group contains 2 while others contain 3 each.
But the problem now is that at PageLoad for the first time the layers of
group1 are not visible because it is getting overlapped by the other layers.
The other layers are also not visible bec' they are mandated to be visible
at higher zoomin levels because of max/min scaledom.
Now if I load the group1 layers last then not only is it visible at initial
zoom level but also at higher zoom levels bec' in that case it is
overlapping the other layers mandated to be visible at that level.
So how to tackle the problem.
Can it be solved by changing the z-index of the first group at initial
PageLoad.
Pls provide some solution to this problem.
Thanks & Regards.
View this message in context: http://n2.nabble.com/Layer-visibility-problem-tp3609424p3609424.html
