[OpenLayers-Users] OpenLayers.js with #1836 patch
Philip Bruvoll pbruvoll at hotmail.com
Thu Sep 10 10:25:01 EDT 2009
I had a suspicion that IE didn't like floating point numbers in this case.
Multiplying with 10 fixes the symbol defined by [0.5,0, 10,8, 0,8, 0.5,0]
But when I use the definition [2,0, 4,5, 0,5, 2,0] which only contains integers,
IE will render it incorrectly. Strangely, multiplying this definition by 10 will
also fix the problem.
Kind regards,
Philip
> Date: Wed, 9 Sep 2009 19:39:23 +0200
> From: ahocevar at opengeo.org
> CC: users at openlayers.org
> Subject: Re: [OpenLayers-Users] OpenLayers.js with #1836 patch
> Mike Adair wrote:
> > If I recall correctly when I was doing something similar, IE didn't
> > accept fractions in the symbol definition.  Scaling it up so that all
> > points were integers solved the problem.
> Good point Mike. Now that you mention it, I think I stumbled across the
> very same issue a long time ago.
> Philip, can you please try to multiply your coordinates by 10 and try
> again? The symbol will not change by doing so. Please report any success
> or failure.
> Thanks,
> Andreas.
> > Mike
> > Andreas Hocevar wrote:
> >> Thanks for the symbol defs, these still render incorrectly in IE indeed.
> >> #1836 needs more work. Patches welcome :-)
> >> Regards,
> >> Andreas.
> >> Philip Bruvoll wrote:
> >>> Thank you for the patch :)
> >>> I have just tried it out.
> >>> It seems that a symbol defined by [2,0, 4,5, 0,5, 2,0] now renders with
> >>> correct size,
> >>> but the position is still wrong (though it has changed). It also
> >>> calculates the center
> >>> wrong, because it moves when it is scaled up.
> >>> The symbol defined by [0.5,0, 10,8, 0,8, 0.5,0] still renders the same
> >>> incorrectly
> >>> way on IE8.
> >>> Does the two symbols above look the same on your machine with IE8 and
> >>> FF/Chrome/Opera?
> >>> Kind regards,
> >>> Philip
> >>>  > Date: Tue, 8 Sep 2009 15:13:32 +0200
> >>>  > To: pbruvoll at hotmail.com
> >>>  > Subject: OpenLayers.js with #1836 patch
> >>>  > as promised. Rename OpenLayers.txt to OpenLayers.js.
> >>>  > Regards,
> >>>  > Andreas.
> >>> With Windows Live, you can organize, edit, and share your photos.
> >>> <http://www.microsoft.com/middleeast/windows/windowslive/products/photo-gallery-edit.aspx>
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
_________________________________________________________________
Share your memories online with anyone you want.
http://www.microsoft.com/middleeast/windows/windowslive/products/photos-share.aspx?tab=1
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090910/b4d130bd/attachment.html
