[OpenLayers-Users] Openlayers and Mapserver
Till Adams adams at terrestris.de
Wed Sep 9 10:08:38 EDT 2009
Alessandro Ronchi schrieb:
> I've set up a mapserver. I can connect to it with qgis, but with
> openlayers I get a blank map.
> This is the url:
> http://ambiente.comune.forli.fc.it/rumore/mappa/
> Do you know what can cause the problem?
> A question: is it possible to get vector layer with openlayer and
> mapserver? I must show polygons informations.
Alessandro,
if OL shows an image - although it is white - I guess you are on the
wrong list....
For Mapserver an empty image could mean:
- you are in the wrong extent (e.g. BBOX and EPSG in your getMap Request
don't fit.)
- there are no objects to be drawn, because you expressions might be wrong
(-->test with  EXPRESSION /./ in the first Class)
I'm sure there are more possible reasons, but it might be worth checking
these first.
In Qgis - depending on the vesion - you'll have to adapt the standard
ESPG number to the EPSG in which your WMS is able to serve.
Regards, Till
terrestris GmbH & Co. KG
Irmintrudisstrasse 17
53111 Bonn
Germany
Till Adams
Geschäftsführung
Tel: +49 (0)228 / 962 899-52
Fax: +49 (0)228 / 962 899-57
adams at terrestris.de http://www.terrestris.de
Amtsgericht Bonn, HRA 6835
Komplementärin:
terrestris Verwaltungs GmbH
vertreten durch:
Hinrich Paulsen, Till Adams
