[OpenLayers-Users] Ovewriting previous map
Surya Tarigan
surya.tarigan at yahoo.com
Wed Sep 9 23:10:30 EDT 2009
Dear Andreas,
it is working now. Thank you very much for the hints and also thank you for Jerome, who has provided script for lonlat input form .
kind regards,
surya
--- On Wed, 9/9/09, Andreas Hocevar <ahocevar at opengeo.org> wrote:
Subject: Re: [OpenLayers-Users] Ovewriting previous map
To: "Surya Tarigan" <surya.tarigan at yahoo.com>
Cc: users at openlayers.org
Date: Wednesday, September 9, 2009, 8:54 AM
Surya Tarigan wrote:
> Dear Andreas,
> I have removed "var" from:
> > var map = new OpenLayers.Map('map', options );
> it stilt doesn't work, firebug give 2 error messages:
> 1) header is null -
> header.style.width=(getWindowWidth()-20) + "px";\r\n
> (I think this error is not critical, it is from resize() function of TMS)
> 2) map is undefined in go() function
Maybe because you call go() before init()? To make sure, you can also define var outside the go and init functions:
<script>
var map;
function init() {}
function go() {}
</script>
Just look at the OpenLayers examples, there are many with forms and do just about the same...
Regards,
Andreas.
> map.setCenter(new OpenLayers.Lonlat(longitude, latitude),5)\r\n
> ( I have fixed zoom value to 5)
> could you please give me further suggestion,
> kind regards,
> surya
> --- On *Tue, 9/8/09, Andreas Hocevar /<ahocevar at opengeo.org>/* wrote:
> From: Andreas Hocevar <ahocevar at opengeo.org>
> Date: Tuesday, September 8, 2009, 10:00 AM
> Hi,
> see my comments inline, and use a javascript debugger like Firebug for
> Firefox to see what is going on.
> > Formerly, I call go() function (see snippet below) which
> handles the
> > map.setCenter, it seems that this function doesn't react to the
> change
> > of lonlat value in drop down list. I have two layers, my base
> layer is
> > a big quickbird image tiled into 6 zoom levels and other layer
> is WMS
> > layer with hundreds of river names. Drop down list should help
> user to
> > pin point selected river in the quickbird image.
> > > When I call init() function it doeas react, but create a series
> of map
> > which doesn't overwrite each other. I certainly do not want to
> create
> > new map every time I change lonlat value, it will double/tripple
> > processing time.
> > > function init(){
> > > var options = {
> > theme: null,
> > maxExtent: new OpenLayers.Bounds(225389.527874, 9627709.46055,
> > 244613.714826, 9639853.34683 ),
> > maxResolution: 103.338482,
> > projection: 'EPSG:4326',
> > units: 'm',
> > controls: [
> > new OpenLayers.Control.LayerSwitcher(),
> > new OpenLayers.Control.MousePosition(),
> > new OpenLayers.Control.PanZoom(),
> > new OpenLayers.Control.ScaleLine()
> > }; //option
> > > var mapBounds = new OpenLayers.Bounds( 225389.527874, 9627709.46055,
> > 244613.714826, 9639853.34683 );
> map is local to the init function here, so it won't be available
> in the
> go() function. Remove "var" to make it global.
> > > var layer = new OpenLayers.Layer.TMS( "TMS Layer","",
> > { url: '', serviceVersion: '.', layername: '.', alpha: true,
> > type: 'png', getURL: overlay_getTileURL });
> > > var river = new OpenLayers.Layer.WMS(
> > "topp:sungai_nr - river", "http://localhost:8080/geoserver/wms",
> > {layers: 'topp:sungai_nr',
> > format: 'image/png',transparent:'true'},{'opacity': 0.2});
> > > map.addLayers([layer, river]);
> > > map.addControl(new OpenLayers.Control.Scale($('scale')));
> > map.setCenter(new OpenLayers.LonLat(231064.944,9631783.43),4);
> > } //function init
> > > function go() {
> > //Get the selected value for lonlat
> > var lonlat =
> document.getElementById('lonlat').options[document.getElementById('lonlat').selectedIndex].value;
> > // Parse the lonlat to get the longitude
> > var longitude = lonlat.substring(0,lonlat.indexOf(','));
> > // Parse the lonlat to get the latitude
> > var latitude =
> lonlat.substring(lonlat.indexOf(',')+1,lonlat.length);
> > // set Center
> > map.setCenter(new OpenLayers.LonLat(longitude,latitude),zoom);
> The above will fail because your map is not known to the go()
> function.
> See my comment above in the init function.
> Also, save yourself some lines of code: instead of calculating
> longitude
> and latitude like above, use
> map.setCenter(OpenLayers.LonLat.fromString(lonlat);
> Regards,
> Andreas.
> -- Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
-- Andreas Hocevar
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090909/bef2a76b/attachment.html
