[OpenLayers-Users] Dynamically refreshing a map built from a single image
ABB waterseller at gmail.com
Fri Sep 11 12:13:33 EDT 2009
Hello,
I have a web service that returns a single PDF image from a given
size/position.
I'm trying to show a map with some zoom/move controls. I tried to use the
OpenLayers.Layer.WMS layer type but my PDF image was automatically
multiplied/resized and the layout was not acceptable. My guess is that the
WMS layer builds the map from small images into a big image (like google
maps).
After failing with WMS, i tried with OpenLayers.Layer.Image but my image is
not automatically regenerated when i move or zoom.
What is the best solution for me? Should i continue with Layer.Image and
implement javascript events in order to automatically call my web service in
order to regenerate the map or i should stick with Layer.WMS?
Any other solutions i should look?
Thank you
View this message in context: http://n2.nabble.com/Dynamically-refreshing-a-map-built-from-a-single-image-tp3626798p3626798.html
