[OpenLayers-Users] Dynamically refreshing a map built from a single image
ABB waterseller at gmail.com
Mon Sep 14 10:21:01 EDT 2009
Got my answer.
In order to "auto-refresh" a single image, OpenLayers.Layer.WMS must be used
with the singleTile option set to true.
Thanks to Kenneth Skovhede (ks at geograf.dk)
ABB wrote:
> Hello,
> I have a web service that returns a single PNG image from a given
> size/position.
> I'm trying to show a map with some zoom/move controls. I tried to use the
> OpenLayers.Layer.WMS layer type but my PDF image was automatically
> multiplied/resized and the layout was not acceptable. My guess is that the
> WMS layer builds the map from small images into a big image (like google
> maps).
> After failing with WMS, i tried with OpenLayers.Layer.Image but my image
> is not automatically regenerated when i move or zoom.
> What is the best solution for me? Should i continue with Layer.Image and
> implement javascript events in order to automatically call my web service
> in order to regenerate the map or i should stick with Layer.WMS?
> Any other solutions i should look?
> Thank you
View this message in context: http://n2.nabble.com/Dynamically-refreshing-a-map-built-from-a-single-image-tp3626798p3642691.html
