[OpenLayers-Users] HELP!!! How implement Filter in WMS Layer
fsalas fsalas at geocuba.cu
Tue Sep 15 12:33:20 EDT 2009
Ian,
as you can see in my code, this time, I pass SLD_BODY without coded. but the
maps don't appears.
The layer is undefined.
Can you send me, other suggestion.
Regards, Salas
***** My CODE *********************************
      Cuba = new OpenLayers.Layer.WMS(
             "Cuba","http://urano:3128/geoserver/wms",
     layers: 'topp:cuba',
                    styles: 'line',
     transparent: 'true'
    {buffer: 0}
      Sennales = new OpenLayers.Layer.WMS(
     "Señales","http://urano:3128/geoserver/wms",
      layers:'topp:sennal',
      SLD_BODY=<StyledLayerDescriptor
version%3D"1.0.0"><UserLayer><Name>topp:sennal</Name><UserStyle><Name>UserSelection</Name>
                                    <FeatureTypeStyle><Rule><Filter
xmlns:gml%3D"http://www.opengis.net/gml"><PropertyIsEqualTo><PropertyName>tipo</PropertyName><Literal>FV</Literal></PropertyIsEqualTo></Filter><PointSymbolizer><Graphic><ExternalGraphic><OnlineResource
xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple"
xlink:href="file:/D:/AppServ/www/SIGANAV/images/FV.gif"/><Format>image/gif</Format></ExternalGraphic><Opacity><Literal>1.0</Literal></Opacity><Size><Literal>20.0</Literal></Size><Rotation><Literal>0.0</Literal></Rotation></Graphic></PointSymbolizer></Rule></FeatureTypeStyle></UserStyle></UserLayer></StyledLayerDescriptor>
      transparent:'true'
   map.addLayers([Cuba,Sennales]);
----- Original Message -----
To: "fsalas" <fsalas at geocuba.cu>
Cc: "Andreas Hocevar" <ahocevar at opengeo.org>; <users at openlayers.org>
Sent: Tuesday, September 15, 2009 9:43 AM
Subject: Re: [OpenLayers-Users] HELP!!! How implement Filter in WMS Layer
> did you try not encoding the SLD in the function body? - it's possible
> that it is being encoded twice and thus makes no sense at the server
> end.
> Ian Turton
> Sent from State College, PA, United States
___________________________________
Dirección de Comunicaciones
Grupo Empresarial GEOCUBA
Este mensaje esta libre de virus.
Revisado por Kaspersky Antivirus
Definition count:  2571166
Definition date:  9/15/2009
SecurityPlus version: 3.0.5
