[OpenLayers-Users] HELP!!! How implement Filter in WMS Layer
Andreas Hocevar ahocevar at opengeo.org
Tue Sep 15 12:00:45 EDT 2009
Use a javascript debugger like firebug to see which requests are issued.
Regards,
Andreas.
fsalas wrote:
> Ian,
> as you can see in my code, this time, I pass SLD_BODY without coded. but the
> maps don't appears.
> The layer is undefined.
> Can you send me, other suggestion.
> Regards, Salas
> ***** My CODE *********************************
>       Cuba = new OpenLayers.Layer.WMS(
>              "Cuba","http://urano:3128/geoserver/wms",
>      layers: 'topp:cuba',
>                     styles: 'line',
>      transparent: 'true'
>     {buffer: 0}
>       Sennales = new OpenLayers.Layer.WMS(
>      "Señales","http://urano:3128/geoserver/wms",
>       layers:'topp:sennal',
>       SLD_BODY=<StyledLayerDescriptor
> version%3D"1.0.0"><UserLayer><Name>topp:sennal</Name><UserStyle><Name>UserSelection</Name>
>                                     <FeatureTypeStyle><Rule><Filter
> xmlns:gml%3D"http://www.opengis.net/gml"><PropertyIsEqualTo><PropertyName>tipo</PropertyName><Literal>FV</Literal></PropertyIsEqualTo></Filter><PointSymbolizer><Graphic><ExternalGraphic><OnlineResource
> xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple"
> xlink:href="file:/D:/AppServ/www/SIGANAV/images/FV.gif"/><Format>image/gif</Format></ExternalGraphic><Opacity><Literal>1.0</Literal></Opacity><Size><Literal>20.0</Literal></Size><Rotation><Literal>0.0</Literal></Rotation></Graphic></PointSymbolizer></Rule></FeatureTypeStyle></UserStyle></UserLayer></StyledLayerDescriptor>
>       transparent:'true'
>    map.addLayers([Cuba,Sennales]);
> ----- Original Message -----
> From: "Ian Turton" <ijturton at gmail.com>
> To: "fsalas" <fsalas at geocuba.cu>
> Cc: "Andreas Hocevar" <ahocevar at opengeo.org>; <users at openlayers.org>
> Sent: Tuesday, September 15, 2009 9:43 AM
> Subject: Re: [OpenLayers-Users] HELP!!! How implement Filter in WMS Layer
>> did you try not encoding the SLD in the function body? - it's possible
>> that it is being encoded twice and thus makes no sense at the server
>> end.
>> Ian Turton
>> Sent from State College, PA, United States
> ___________________________________
> Dirección de Comunicaciones
> Grupo Empresarial GEOCUBA
> Este mensaje esta libre de virus.
> Revisado por Kaspersky Antivirus
> Definition count:  2571166
> Definition date:  9/15/2009
> SecurityPlus version: 3.0.5
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
