[OpenLayers-Users] Problem with styling vectorfeatures depending on their attributes
Andreas Hocevar ahocevar at opengeo.org
Thu Sep 17 11:46:39 EDT 2009
Hey Paul,
I had totally forgotten about this ticket. I combined the 2nd patch with
the test from the 1st patch and uploaded a new patch that you can commit.
Thanks for that contribution, it will make styling easier for sure.
Regards,
Andreas.
Paul Spencer wrote:
> http://trac.openlayers.org/ticket/2146 may help, I filed this a while
> back with a patch to make it possible to use a context and attribute
> map.  This lets you use ${} for feature styling from attributes and
> methods in a context:{} at the same time, reducing the perceived
> overhead of adding a function for every attribute you want to map.  At
> the same time, the patch also modifies what is passed to a context
> function to include the name of the attribute being calculated, which
> means you can use a single function to handle multiple attributes.
> This means you can do something like this contrived example:
> new StyleMap({
>    default: {
>      fillColor: "${fillColor}", // should come from feature.attributes
>      strokeWidth: "${getStyle}", // should come from getStyle
> function, +2 on attribute value
>      strokeColor: "${getStyle}" // should come from getStyle function,
> just strokeColor attribute though.
>    context: {
>      getStyle: function(feature, attribute) {
>        if (attribute == 'strokeWidth') {
>          return feature.attributes.strokeWidth + 2;
>        } else {
>          return feature.attributes[attribute];
> Not sure if this is useful for you.
> Cheers
> Paul
> On 2009-09-17, at 10:19 AM, Max Stephan wrote:
>> Hi Andreas,
>> Thank you for that hint. I already found that out to but it doesn´t
>> help me
>> with solving my problem. I prefer to avoid using the context because
>> of
>> this. Any other ideas on this?
>> greets
>> Max Stephan
>> Andreas Hocevar-2 wrote:
>>> Max Stephan wrote:
>>>> Hi list,
>>>> I have a vectorlayer to which the user can add features and modify
>>>> those
>>>> features. The user can change the attributes for the features like
>>>> fillColor, strokeColor etc. in a form. A javascript-method is
>>>> executed by
>>>> a
>>>> button-click and saves those attributes as vectorattributes (e.g.
>>>> feature.attributes.fillColor).
>>>> In the styleMap I´m reading those values from the vectorattributes
>>>> to
>>>> change
>>>> the styling. The stylemap-Code looks like this:
>>>> var pointStyleMap = new OpenLayers.StyleMap({
>>>> 	"default": new OpenLayers.Style({
>>>> 	fillOpacity: 0.5,
>>>> 	strokeColor: "${strokeColor}",
>>>> 	strokeWidth: "${strokeWidth}",
>>>> 	pointRadius: 10,
>>>> 	graphicZIndex: "${graphicZIndex}"
>>>> 	"select": new OpenLayers.Style({
>>>> 	pointRadius: 10,
>>>> 	strokeColor: '#FF3333',
>>>> });This works so far. But now I want to add 2 to the strokeWidth
>>>> when the
>>>> feature is selected, so I tried it like this:
>>>> strokeWidth: "${strokeWidth}" + 2The effect is that the 2 is only
>>>> appended
>>>> (the code seems to interprete strokeWidth as a String although I
>>>> parsed
>>>> it
>>>> to an Int via parseInt(), e.g. for a strokeWidth of 2 I get 22 as a
>>>> result).
>>>> It´s possible to solve this problem by defining a context for the
>>>> style
>>>> but
>>>> in my opinion that´s a little overkill for such a simple task.
>>>> {context:
>>>> 	{strokeWidth: function (feature){return
>>>> (feature.attributes.strokeWidth
>>>> 2)}}
>>>> }Now I want to get the pointRadius from the attributes but no matter
>>>> which
>>>> method I try, it always ends in the error message: "Line: 625
>>>> Column:
>>>> 408,
>>>> invalid Argument (OpenLayer.js)". Also tried to parse it to an Int
>>>> again
>>>> directly in the styleMap .. no effect.
>>>> I have to use IE for this project so no further debug information is
>>>> available (I´m also not able to install IE8 with it´s debugging
>>>> features
>>>> due
>>>> to limited admin rights at my workstation).
>>>> Any idea how I could solve this problem?
>>> As soon as you define a context, feature.attributes will no longer be
>>> what is available in the template. So you should define your context
>>> like this:
>>> context: {
>>>    strokeWidth: function(feature){...},
>>>    strokeColor: function(feature){...},
>>>    fillColor: function(feature){...},
>>>    graphicZIndex: function(feature){...},
>>>    pointRadius: function(feature){...}
>>> Regards,
>>> Andreas.
>>>> Thx in advance
>>>> Max Stephan
>>> Andreas Hocevar
>>> OpenGeo - http://opengeo.org/
>>> Expert service straight from the developers.
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
>> View this message in context: http://n2.nabble.com/Problem-with-styling-vectorfeatures-depending-on-their-attributes-tp3663197p3663407.html
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
> Users mailing list
Andreas Hocevar
