[OpenLayers-Users] Problem with styling vectorfeatures depending on their attributes
Paul Spencer pagameba at gmail.com
Thu Sep 17 13:18:10 EDT 2009
Thanks Andreas, I've committed your last patch.
Cheers
Paul
On 2009-09-17, at 11:46 AM, Andreas Hocevar wrote:
> Hey Paul,
> I had totally forgotten about this ticket. I combined the 2nd patch
> with the test from the 1st patch and uploaded a new patch that you
> can commit.
> Thanks for that contribution, it will make styling easier for sure.
> Regards,
> Andreas.
> Paul Spencer wrote:
>> http://trac.openlayers.org/ticket/2146 may help, I filed this a
>> while  back with a patch to make it possible to use a context and
>> attribute  map.  This lets you use ${} for feature styling from
>> attributes and  methods in a context:{} at the same time, reducing
>> the perceived  overhead of adding a function for every attribute
>> you want to map.  At  the same time, the patch also modifies what
>> is passed to a context  function to include the name of the
>> attribute being calculated, which  means you can use a single
>> function to handle multiple attributes.
>> This means you can do something like this contrived example:
>> new StyleMap({
>>   default: {
>>     fillColor: "${fillColor}", // should come from feature.attributes
>>     strokeWidth: "${getStyle}", // should come from getStyle
>> function, +2 on attribute value
>>     strokeColor: "${getStyle}" // should come from getStyle
>> function,  just strokeColor attribute though.
>>   context: {
>>     getStyle: function(feature, attribute) {
>>       if (attribute == 'strokeWidth') {
>>         return feature.attributes.strokeWidth + 2;
>>       } else {
>>         return feature.attributes[attribute];
>> Not sure if this is useful for you.
>> Cheers
>> Paul
>> On 2009-09-17, at 10:19 AM, Max Stephan wrote:
>>> Hi Andreas,
>>> Thank you for that hint. I already found that out to but it doesn
>>> ´t  help me
>>> with solving my problem. I prefer to avoid using the context
>>> because  of
>>> this. Any other ideas on this?
>>> greets
>>> Max Stephan
>>> Andreas Hocevar-2 wrote:
>>>> Max Stephan wrote:
>>>>> Hi list,
>>>>> I have a vectorlayer to which the user can add features and
>>>>> modify  those
>>>>> features. The user can change the attributes for the features like
>>>>> fillColor, strokeColor etc. in a form. A javascript-method is
>>>>> executed by
>>>>> a
>>>>> button-click and saves those attributes as vectorattributes (e.g.
>>>>> feature.attributes.fillColor).
>>>>> In the styleMap I´m reading those values from the
>>>>> vectorattributes  to
>>>>> change
>>>>> the styling. The stylemap-Code looks like this:
>>>>> var pointStyleMap = new OpenLayers.StyleMap({
>>>>> 	"default": new OpenLayers.Style({
>>>>> 	fillOpacity: 0.5,
>>>>> 	strokeColor: "${strokeColor}",
>>>>> 	strokeWidth: "${strokeWidth}",
>>>>> 	pointRadius: 10,
>>>>> 	graphicZIndex: "${graphicZIndex}"
>>>>> 	"select": new OpenLayers.Style({
>>>>> 	pointRadius: 10,
>>>>> 	strokeColor: '#FF3333',
>>>>> });This works so far. But now I want to add 2 to the
>>>>> strokeWidth  when the
>>>>> feature is selected, so I tried it like this:
>>>>> strokeWidth: "${strokeWidth}" + 2The effect is that the 2 is only
>>>>> appended
>>>>> (the code seems to interprete strokeWidth as a String although
>>>>> I  parsed
>>>>> it
>>>>> to an Int via parseInt(), e.g. for a strokeWidth of 2 I get 22
>>>>> as a
>>>>> result).
>>>>> It´s possible to solve this problem by defining a context for
>>>>> the  style
>>>>> but
>>>>> in my opinion that´s a little overkill for such a simple task.
>>>>> {context:
>>>>> 	{strokeWidth: function (feature){return
>>>>> (feature.attributes.strokeWidth
>>>>> 2)}}
>>>>> }Now I want to get the pointRadius from the attributes but no
>>>>> matter
>>>>> which
>>>>> method I try, it always ends in the error message: "Line: 625
>>>>> Column:
>>>>> 408,
>>>>> invalid Argument (OpenLayer.js)". Also tried to parse it to an
>>>>> Int  again
>>>>> directly in the styleMap .. no effect.
>>>>> I have to use IE for this project so no further debug
>>>>> information is
>>>>> available (I´m also not able to install IE8 with it´s debugging
>>>>> features
>>>>> due
>>>>> to limited admin rights at my workstation).
>>>>> Any idea how I could solve this problem?
>>>> As soon as you define a context, feature.attributes will no
>>>> longer be
>>>> what is available in the template. So you should define your
>>>> context
>>>> like this:
>>>> context: {
>>>>   strokeWidth: function(feature){...},
>>>>   strokeColor: function(feature){...},
>>>>   fillColor: function(feature){...},
>>>>   graphicZIndex: function(feature){...},
>>>>   pointRadius: function(feature){...}
>>>> Regards,
>>>> Andreas.
>>>>> Thx in advance
>>>>> Max Stephan
>>>> Andreas Hocevar
>>>> OpenGeo - http://opengeo.org/
>>>> Expert service straight from the developers.
>>>> _______________________________________________
>>>> Users mailing list
>>>> Users at openlayers.org
>>>> http://openlayers.org/mailman/listinfo/users
>>> View this message in context: http://n2.nabble.com/Problem-with-styling-vectorfeatures-depending-on-their-attributes-tp3663197p3663407.html
>>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>>> Users mailing list
>> Users mailing list
> Andreas Hocevar
